Old 03-16-2015, 04:22 PM   #1
ApacheStan
Post '59 Apache: Need help with Front Cab Floor support Brackets
Does anyone know how to replace the front cab floor support brackets in a 1959 Chevy Apache stepside? I think they are also called Front Cab mounts maybe. I have the assembly manual and can't find anything about them.
Thanks,
Stan
ApacheStan is offline   Reply With Quote
Old 03-17-2015, 10:13 AM   #2
Spblack
Spblack's Avatar
Re: '59 Apache: Need help with Front Cab Floor support Brackets
Thanks,
Stan
they sell them in the LMCtruck catalog.
1959 Chevy Apache (sold)
1958 Fleetside Current
My builds:
http://67-72chevytrucks.com/vboard/s...d.php?t=606412
http://67-72chevytrucks.com/vboard/s...=1#post7560906
Spblack is offline   Reply With Quote
Old 03-17-2015, 11:05 AM   #3
ApacheStan
I saw those but how do you replace them?
Old 03-17-2015, 11:56 AM   #4
Spblack
Spblack's Avatar
Cut yours out, I think they are spot welded in there. So you may have to use a wire brush on the inside of the floorboard to see the spot welds and drill them out. Use a pry bar and start working.
My builds:
Old 03-17-2015, 12:44 PM   #5
ApacheStan
So are they spot welded to the floor pan or the crossmemeber? Meaning do the just rest on the crossmember?
Old 03-17-2015, 01:35 PM   #6
bowt1ed
They are spot welded to the firewall/toeboard (actually the firewall/toeboard is spot welded to the crossmember). However, the floor is also spot welded to the firewall/toeboard just behind it, so you will likely have to drill those out to. I just replaced my firewall/toeboard with a new one from Dynacorn (excellent fit), but since I still had great front mounting pads and crossmember, just cut the new one out around them and flush welded - now much stronger than original. Cheers, Jim
bowt1ed is offline   Reply With Quote
Old 03-17-2015, 02:37 PM   #7
ApacheStan
Thanks All!!!!
