Old 03-17-2015, 12:55 PM   #1
Coach
Coach's Avatar
Camshaft swap on SB 350/290hp
Hey guys, looking for some advice. I have a Chevy Performance SB 350/290hp in my C10. She runs fine, but I know she is capable of more, especially when it comes to low end torque and acceleration. I have seen many posts on this site about the stock camshaft being a bad match for this engine. I am thinking about swapping it out. Don't need a street demon, just something with a little more low end torque and acceleration. Don't want to burn through tires, but a little bark would be nice. Any suggestions on the right cam would be appreciated, thanks.
1967 Chevy C10 Stepside SWB - 350/700r4
Coach is offline   Reply With Quote
Old 03-17-2015, 01:08 PM   #2
GRX
GRX's Avatar
Re: Camshaft swap on SB 350/290hp
The Melling MTC-1 RV/towing cam was a common upgrade for many years. Thus they can be had pretty cheap.
GRX is offline   Reply With Quote
Old 03-17-2015, 01:48 PM   #3
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Go over to engine/drivetrain section. Always good discussions on this subject.
http://67-72chevytrucks.com/vboard/f...splay.php?f=24
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 03-17-2015, 01:52 PM   #4
enaberif
12-300-4 allows all stock components but has enough low down grunt.
enaberif is offline   Reply With Quote
Old 03-17-2015, 05:59 PM   #5
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Check out the Lunati cams. Good options there.
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 03-17-2015, 06:52 PM   #6
JJLT1
JJLT1's Avatar
what rear gears?
how is your timing set up?
JJ
71 SWB 360 Th400 4.56
JJLT1 is offline   Reply With Quote
Old 03-17-2015, 09:12 PM   #7
Coach
Coach's Avatar
Rear gears are 3.73 with a 700r4 transmission (which will being rebuilt at the same time the cam is swapped out). The base timing is 16 ( no detonation) with total timing at 36 (vacuum advance is hooked up.
