Bagged with big wheels/tires
What are you guys doing about the inner fenders to strengthen them? I havent even had my truck on the street yet and have already bent the inner lip of the fender accidentally when turning to far while driving low. This is with 1" narrower a-arms.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Bagged with big wheels/tires
This is one on the best designed bagged 60-66 inner fenders I've seen.
![]() Join Date: May 2007
those are gorgeous!
mine are simliar to another guy on this forum, we trimmed the fender out for more turning space as well. ![]() ![]()
bump to find my way back to those sweet inners.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
Here's what I did
[QUOTE=61 apache 10;7097445]Here's what I did
what did you use for the inners themselves? Trailer tubs? |
![]() Join Date: Mar 2013
That V6 is sweet! 305?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#8 | |
[quote=biohazardbill;7097452]
#9 | |
[quote=61 apache 10;7097460]
what do you mean by banded? |
#10 | |
[quote=biohazardbill;7097726]
The picture of the fender in primer shows an over lapping edge to finish to the wheel well. It's hard to see in this picture, but the inner wheel well and the fender are 2 separate pieces. The red arrow is pointing to the part line. Same deal as the red truck posted at the top of this thread, except the fit was perfect and didn't need half a dozen bolts to hold it together. I also followed the original taper when joining it to the core support. "Banded" I used the 2 edges from a trailer fender and added a strip in the middle to make the tub wider. I used another trailer fender edge and attached it to the truck fender to make a lap joint where the fender bolts to the wheel well. Hope this helps Last edited by 61 apache 10; 03-19-2015 at 10:27 PM. |
#11 | |
[quote=61 apache 10;7097987]
Yes this helps thanks. Yes the motor is a 305, and the 6 bolts are to retain a somewhat factory appearance. I spoke with the guy that owns the truck. Super nice guy. |
