03-20-2015, 01:39 PM | #351 | |
Re: What did you do with your truck today, take 2
BUT - I have my filler mocked up there right now and it was a royal pain in the arse to fuel up, so I am now thinking I will just put the filler in the bed floor. So much for being original eh? Jake |
03-20-2015, 02:37 PM | #352 |
I mounted my tank on the bottom of the frame and I'm going to either drill thru,or notch out the bottom of the rear sill. Doesn't look there will be any issue with the angle of the filler.
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
03-22-2015, 05:04 PM | #353 |
Installed steering wheel.
1958 Apache short bed |
03-22-2015, 06:08 PM | #354 |
patch panels stuff not picture worthy
. found this on the web looks like a TF truck...Sp . . . . . . . . .. . .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
03-30-2015, 05:52 PM | #355 |
This post is a duplicate of what I just posted on my own thread. I do that to keep all my stuff together but posting here so if anyone is interested they'll find it:
Took the day off today. I think I caught a case of "anal glaucoma" - I couldn't see my a$$ going to work today! Decided to do a little project I've been putting off.... painting the white on some nice original side badges I bought from a guy in NY. They were rechromed at some point and I n doing it they lost a lot of the lower edge of the smaller letters in "Chevrolet" but I don't mind. Basically, I just masked the large details as well as I could, and used Duplicolor touch up paint, both primer/filler and bright white top coat. The small brush that comes with the paint is good enough to follow the edges of the small letters; though they've lost some definition. Anyway, here's my progress so far: And the other end: Here's the mateirals I'm using. No prep - didn't want to scratch the good chrome. We'll see if this turns out to be a mistake or not.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! Last edited by Dan in Pasadena; 03-30-2015 at 06:19 PM. |
03-31-2015, 10:52 AM | #356 |
Stalker Nate
Finally had its first bath since last summer lol Put a manual rack in it to drive it while I wait on the power rack. Not very easy to drive with manual lol The '46 is easier to drive as a manual.
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
04-04-2015, 01:21 PM | #357 |
Just dropped mine off with a guy that's gonna rebuild the TH350. It had developed a bad leak and I know nothing about the history of the tranny so figured I may as well bite the bullet for a full rebuild. Also having him install a used Lokar floor shifter I found on Craigslist and hook up the speedometer cable.
I'd recently rebuilt the carb but hadn't adjusted anything, just plopped it on there and took it to the guy. Hopefully it'll idle down nicely and run better without leaving a big red stain the on the driveway anymore.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
04-04-2015, 01:38 PM | #358 |
Brought home the donor S10 w/ 5.7L and 700r.
All body panels stripped down to bare metal and primed (except bed) Have a buyer coming for the original chassis and once its gone I will pull the donor around back and strip the body off and begin the build. |
04-04-2015, 01:39 PM | #359 |
Finished making Dash Cluster Inserts
04-04-2015, 02:09 PM | #360 |
Mounted the newly stained & urethane'd steering wheel.
A little darker / glossier than I'd hoped but hey, the Minwax was just sitting there on the shelf.
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. |
04-04-2015, 02:20 PM | #361 |
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
04-05-2015, 02:08 PM | #362 |
Finished the new frame C notches, rechecked level and checked again for square. It's bang on! Been a ton of work getting to this point as the frame was tweaked.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 |
04-05-2015, 05:00 PM | #363 |
Took out the dash gauges, put a pair of new hinges on drivers door, still need to do passenger side.
Removed the wiring from the cab in anticipation to new wiring from American autowire.
1954 Chevy 3100 currently original. |
04-11-2015, 05:20 PM | #364 |
Working on making new door panels and then came the little brown truck with a package. It took 8 months to get these but it was worth it.
04-11-2015, 07:28 PM | #365 |
Pretty shiney crossfire! What's up with the 8 months?
04-11-2015, 07:30 PM | #366 |
Redid my C notches today. Freak'in all day! I'm done! Now me and the boy's time. Hockey night in Canada and then off to the sack.
04-11-2015, 08:39 PM | #367 |
Not just what I have done today, but I thought it would be time for an update.
Picture of what the truck looked like when I bought it last August. Now after finding a different frame to put under it, changing it from 4WD back to 2WD, changint the engine, transmission, all suspension and lowering 5 inches front and back. Just mocked up the cab and bed and setting the fenders and hood back in place. I am liking the look of this truck again. |
04-11-2015, 10:05 PM | #368 |
installed new windshield.
tbrown's 56 Cameo Build |
04-11-2015, 11:10 PM | #369 |
Vortec 4200 with AR5 trans.
04-12-2015, 10:47 AM | #370 |
I bought these from Jim Carter last year, Since these are not a big seller he does not stock a big supply so he waits till there is demand then has the foundry cast up a dozen pair. Then off to the plater. (foundry and plater are in the USA). I knew this when I ordered these.
04-12-2015, 10:49 AM | #371 |
You need a build thread in your signature.
04-12-2015, 10:56 AM | #372 |
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
04-12-2015, 04:54 PM | #373 |
[QUOTE=MARTINSR;7129896]Interesting!
I was kind of convinced of this swap a couple years ago. It's taken me awhile to get around to doing anything. Mainly I had to get rid of the 235. Well the 235 left my garage about 2:30 Saturday and by 4:00 I wedged everything in there. (Literally, I wedged it in. I can show you the Gorilla bar later.) I'm liking how it's fitting. I'm going to have to notch the front crossmember slightly. If I had a GMC, I don't think I would need to notch anything at all since the crossmember is lower. The upper coolant outlet on the engine is going to have to be modified. Not to mention the oil pan is going to have to be notched and oil pickup modified to clear the solid axle. All in all, it's a pretty straight forward swap. I'm going to cut out the old rear engine crossmember though. It doesn't really need to come out, but if I would ever need to work on the transmission, I would have to blow apart the frontend and remove the Engine/Trans. all in one. I think I'll weld some flanges on the crossmember so it can be reinstalled though, since it is a structural component to the frame. I hate saying this, but the 5 cylinder from the Colorado/Canyon would be a much easier swap. Almost a direct drop in. Rear sump oil pan, and 4 inches shorter would make a world of difference. Chris |
04-12-2015, 05:49 PM | #374 | |
Forgodsake, though, please document this and make a build thread. It is just too cool to go unnoticed.
04-12-2015, 07:39 PM | #375 |
Went to a local car show at a church today and had it blessed! I figured it couldn't hurt, just saying!
