Old 03-22-2015, 08:56 AM   #1
nateshrek
Offenhauser Single Quad Intake Manifold thoughts
Morning gentlemen, I'm thinking about putting a Offenhauser Single Quad Intake Manifold on my stock 250, carb unknown at this point. What's your experiences with this, stories, and any knowledge as it if it is a good idea, bad or will just end up ugly.
As always, thanks for your thoughts.
Cheers.
nateshrek is offline   Reply With Quote
Old 03-22-2015, 09:56 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Offenhauser Single Quad Intake Manifold thoughts
I ran one on my 194 in my 1963 Chevy II from 1982 to 1990 with a Holley 390 cfm carb. At that time, it was my daily driver in high school and college (and weekend bracket car). In addition to better wide open throttle performance, it gave me a significant bump in fuel mileage over the 1bbl Rochester.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-22-2015, 10:19 AM   #3
nateshrek
Did it give you more power? Make it more snappy?
Old 03-22-2015, 11:02 AM   #4
vin63
vin63's Avatar
Yes, but, in my case, that was primarily a result of the carburetor.
Old 03-22-2015, 11:06 AM   #5
TJ's Chevy
TJ's Chevy's Avatar
If your going to do a 4 barrel you may as well do headers. Personally I like the clifford manifold alot better, better quality and more user friendly. Much more expensive but also easier to install. But I know of alot who have used the offy and few complaints thus far. A good set of headers would be at Langdon's Stovebolt.com. You notice more power with the headers as well. A GM hei wouldn't be a bad idea either. The 4 barrel, headers, hei swap will give you a little better mileage, little more power through the rpm, and will make it a little snappier as well. Don't expect 100 more hp with just those mods. This swap gives at most extra 30 hp. Enough to feel a difference. I'd subscribe to Inliner's International. com to get the best info. Alot of guys on there who have actually done these swaps and can tell you more exact hp gains and such. Subscribed there myself when I rebuilt my hopped up 292. They know they're stuff. Anyhow, hope you enjoy having fun with your 250! If you have any other questions feel free to PM me or I can PM you my number.
Old 03-22-2015, 02:26 PM   #6
DakotaKid
make sure you put the water in the manifold for Intake heat. otherwise they are cold blooded as hell. i had a 250 with the clifford intake and after i put the water heated part on the intake it ran much better.
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
250, 4 barrel, carb, manifold, question
