Old 03-22-2015, 03:34 PM   #1
Guilty-by-Design
Guilty-by-Design's Avatar
Where can i find one of these
looking for #5, only place i can find one is LMC. i have had no luck looking on oreillys autozone napa or amazon. i need it for my 82 c10 with a 305.
i have been searching booster line, booster hard line, booster vacuum line... dose it have another name? any help would be appreciated.
Guilty-by-Design is offline   Reply With Quote
Old 03-22-2015, 04:09 PM   #2
Titomars
Titomars's Avatar
Re: Where can i find one of these
Well if you can not find one pre-made, the line is standard 3/8th inch steel line. Get a universal replacement at a parts store and bend to fit then just cut off the 2nd threaded end and surplus for a slip fit to the hose. Another alternative is poke around a wrecking yard. That is not a high demand part out there. So there should be lots of them. Also look on cars with a similar engine package.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 03-22-2015, 06:30 PM   #3
SCOTI
SCOTI's Avatar
x2. I made my own from steel tube purchased @ oreillys. The benefit to me was I re-routed it to clean-up the look when I made it & used vacuum line to go back to the intake.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-22-2015, 06:54 PM   #4
Guilty-by-Design
thankyou guys, i may just order it from lmc if i cant find one in the junk yard tomorrow.
Old 03-23-2015, 12:07 AM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Or a barb fitting and a vacuum hose.
Old 03-23-2015, 12:11 AM   #6
enaberif
Exactly this. Unless you are trying to restore to as close to factory as possible just get a 3/8 NPT nipple and use a rubber vac line.
enaberif is offline   Reply With Quote
Old 03-23-2015, 12:40 AM   #7
Guilty-by-Design
i asked the guy at the part store for something like that because i didn't want to mess with flaring and bending my own line and he looked at me like i was retarded... so a 3/8 NPT barb/nipple is what im after thankyou KQQL IT and enaberif
Old 03-23-2015, 01:00 AM   #8
Titomars
Titomars's Avatar
I guess you went to the wrong parts store. I tend to forget many use those Pepboy's, OReilly's, Autozone's, and others of that caliber. I only use old school full service parts Stores like Napa. Here is a photo of a generic replacement steel line I was refering to. They are sold in common sizes from 3/16 to 1/2 inch and from 12 to 60 inches long.
Old 03-23-2015, 01:06 AM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
anytime, I'm not sure if the check valve is for. Ran mine with and with out one.
Old 03-23-2015, 01:16 AM   #10
SCOTI
SCOTI's Avatar
Check valve should help hold vacuum to the diaphragm.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-23-2015, 01:31 AM   #11
KQQL IT
At the body shop.
KQQL IT's Avatar
The catalog calls it a filter? I broke mine last time the engine was out. Didn't notice much difference...
Old 03-23-2015, 01:38 AM   #12
Titomars
Titomars's Avatar
The filter is to keep gasoline and oil vapors out of the booster during a backfire. The booster diaphragm does not like those chemicals much.
Old 03-23-2015, 09:06 AM   #13
enaberif
Check valve is to hold vacuum in the booster. If you drive your truck around then pull out the check valve you'll hear a loud pop or hiss sound as the air escapes.
If you hear neither of these when you pull out the check valve you either have a bad check valve or a bad booster.
Old 03-23-2015, 11:36 AM   #14
Chaplain
Chaplain's Avatar
PM sent
Chaplain is offline   Reply With Quote
Old 03-23-2015, 12:38 PM   #15
jetmech85
Pretty sure I have one I can give you. PM me.
jetmech85 is offline   Reply With Quote
Old 03-23-2015, 01:48 PM   #16
Guilty-by-Design
thank you all for the help. i just got back from napa (they were closed yesterday) with a barb and vac line so everything is working well. i kept the filter and check valve but i pulled the valve from the booster to see if it was holding vacuum and was caught a little off guard by how much vacuum it still had... thank you all again
Old 03-23-2015, 01:51 PM   #17
enaberif
LOL yeah it will pop pretty good
Old 03-24-2015, 03:16 AM   #18
KQQL IT
At the body shop.
KQQL IT's Avatar
Good deal.
