03-22-2015, 09:38 PM | #1 |
Finally got to second base took her top off!
I even took pictures!
03-22-2015, 09:44 PM | #2 |
I'm trying....
Re: Finally got to second base took her top off!
Universal Truth: They all look better topless.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
03-22-2015, 10:19 PM | #3 |
Does this look like a stock height?
I thought it was all original stock other then paint but found it has a 42 gallon gas tank so maybe it has been lifted too? The current tires are 31x10.50R15LT's I would love to put 35x12.5x15 BFG MTs if they even make that size on it without raising it more but I was told in a thread it would rub at a stock height. Just wondering. How can I confirm? Thanks PG |
03-24-2015, 06:35 AM | #4 |
Better when the perky like this too......We are going to need more pictures! Great looking truck, looks like stock height to me. Check the springs and shackles for lift, you should be able to tell.
03-24-2015, 11:35 PM | #5 |
SKINNY TIRES RULE!
Good looking truck. I like it with the stock wheels and height. Not many original survivors left. I get tons of looks and complements in my truck with the steelies and dog dish hub caps.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
03-25-2015, 12:16 PM | #6 |
Looks great with the top off! Sure looks like stock height to me. Shoot some pics of the springs and we can tell you pretty easily.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
03-25-2015, 02:54 PM | #7 |
If the front springs have a negative arch (bow upward), then you have stock front springs. All lift springs have a positive (bows downward) arch. In the rear, check to see if there are lift blocks between the springs and perches. If you have blocks, you have a lift. If you have no blocks, you could still have lift springs. Hope this helps.
03-25-2015, 04:21 PM | #8 |
I crawled under it and its not lifted. Thanks guys PG
03-27-2015, 12:03 PM | #9 |
Beautiful blazer PG I think it looks perfect as is.
------------ Scott |
03-28-2015, 02:51 PM | #10 |
Thanks skunk99 I am planing on doing very little to it.
I would like to add a roll bar and have replaced the stock AM radio with a slide bar from Custom Autosound's the shipment showed up with one damaged speaker from UPS and the slide bar feature was not working its getting replaced today. I also have a set of wheels and 33x12.5x15 BFG MT's going on soon. Thanks PG |
03-28-2015, 04:15 PM | #11 |
Active Member
I think it is a great decision to leave the stock lift in it.The top has been off of mine for almost 2 yrs. I keep it under a carport.
03-28-2015, 04:23 PM | #12 |
blowns that is a large amount of cocaine you have that K5 parked in!
Looks good I would drive mine in the snow too! PG |
03-28-2015, 04:26 PM | #13 |
Active Member
I only drove it around the neighborhood to keep most of the salt of of it. The sun was out and it was too tempting!
03-28-2015, 04:59 PM | #14 |
Very nice truck. One of my favorite colors for them too.
03-28-2015, 06:33 PM | #15 |
Tops off, but she's not leaving the garage til there's no more snow and the salts all washed away!
