Old 03-22-2015, 10:20 PM   #1
class01
class01's Avatar
separating transmission
Trying to separate my 6l80 transmission from the motor. Got all the bolts on the case out anything else i need to do because its not budging.
class01 is offline   Reply With Quote
Old 03-22-2015, 11:41 PM   #2
clinebarger
Re: separating transmission
Remove the torque converter bolts! There are 2 bellhousing bolts into the oil pan, And 6 in the block.
The trans is stuck on the Dowel Pins, Very common issue, One or both will come out of the block with the trans, Rock the trans side to side, Then up & down.
clinebarger is offline   Reply With Quote
Old 03-23-2015, 10:13 AM   #3
class01
class01's Avatar
thanks clinebarger. I knew i had to be missing something
