Old 03-23-2015, 02:01 PM   #1
Matthewjb
Rubber Coating on floor pan
I have a one piece floor that I'm installing with the black EDP primer. My question is when I spray some rubberized coating to protect the bottom should I just spray right over the black EDP? Also, anyone have any suggestions for under coating...I was looking at some at NAPA about $20 a can.
Matthewjb is offline   Reply With Quote
Old 03-24-2015, 06:19 AM   #2
flykelley
Re: Rubber Coating on floor pan
I used the urethane coating on mine, drys hard not soft like the rubber undercoating. Iy cost more but well worth it.
Mike
flykelley is offline   Reply With Quote
Old 03-24-2015, 06:48 AM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Honestly I would epoxy prime and paint over a scuffed EDP then undercoat afterwards. The undercoating creates pockets that moisture can get into. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 03-24-2015, 10:06 AM   #4
Step away from the rubber coating! Whatever you decide to use (and I suggest not using rubberized coating) you most definitely want to paint first. There are way better coatings for this application. look around and make an educated decision. Replacing a floor is too big a job to be putting the wrong stuff on
Old 03-24-2015, 01:30 PM   #5
Matthewjb
Ok, awesome. Thanks for help everyone.
Old 03-24-2015, 01:56 PM   #6
sboris
sboris's Avatar
Just throwing this out there. I did inside and out w/epoxy prime, then a couple coats of por 15. I expect no rust.. Could then undercoat to help with noise and heat if ya choose, but the point is you need a good base under the under coat.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 03-24-2015, 03:34 PM   #7
sduckworth13
sduckworth13's Avatar
Sboris, did you use the etch prep on top of the epoxy primer prior to putting on the POR15.
Scott
sduckworth13 is offline   Reply With Quote
Old 03-24-2015, 03:51 PM   #8
sboris
sboris's Avatar
No i hit it lightly w/ da sander and scuffed real good the rest.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 03-24-2015, 05:00 PM   #9
LockDoc
The Older Generation
LockDoc's Avatar
I have used 3M Body Schutz on the last 3 vehicles I have done. I have been very happy with it...
http://www.hemmings.com/hmn/stories/...feature19.html
If you do a search on Google or Bing you will find more info on it.
LockDoc
Leon
Old 03-25-2015, 12:35 PM   #10
67chevemall
67chevemall's Avatar
Yep paint them with a good paint and buy a rubber floor insert. Or carpet if that is your cup of tea.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
