03-23-2015, 11:35 PM | #1 |
ECE disc brakes installed
ECE front disc brakes installed and stock wheels are a no fit. I knew that this was going to be an issue. Any idea on what 15 x 6 inch 6 lug wheel will fit? Blazer? Just had my 5 stock wheels blasted and powder coated. J
03-23-2015, 11:55 PM | #2 |
Re: ECE disc brakes installed
6 lug from 71 and newer k5 or k10 will work. They're identifiable by 4 nubs to mount the caps on instead of 3... Sucks you already had those coated!
03-24-2015, 12:42 AM | #3 |
Ran into a similar problem. just look on the inside of the wheel, some have a slanted inner part to the rim that contours the drum brake (they don't fit the discs) you just have to find a rim with a squared off inside, and that should fit just fine. I'm not sure of any particular year, but that's what I had to do.
hope that makes sense.... |
