Old 03-24-2015, 05:45 PM   #1
6768chevylover
6768chevylover's Avatar
cheap solution to heat mats
Im lookng for a sound deadener but for the heat and im looking for a cheap solution to do it.. any suggestions? does home depot or lowes have something?
6768chevylover is offline   Reply With Quote
Old 03-24-2015, 06:00 PM   #2
sk8er32283
Re: cheap solution to heat mats
Which heat source are you trying to stop? If it is the exhaust you might do an exhaust wrap or heat shield. This would be rather cheap and less time consuming that removing a lot of the interior.
1971 Chevrolet C10(78 motor), Longbed, 69 Bed I think
Quadrajet 4 barrel 7043208, Th350 tranny, No A/C
Various components are lightly to highly modified depending on the number of beers consumed prior to modifications performed.
sk8er32283 is offline   Reply With Quote
Old 03-24-2015, 09:24 PM   #3
Tinkermc
Lowe's sells a decent heat retardant in rolls with sticky back, about 1/4 " thick, cheap and effective.
Tinkermc is offline   Reply With Quote
Old 03-24-2015, 09:28 PM   #4
hotrodder
Thumbs up Re: cheap solution to heat mats
Lowes has a product called peel & stick. It is on the same lines as Dynamat. I found it in the section where insulation is for heating and cooling. works real good and reasonable price.
hotrodder is offline   Reply With Quote
