Old 03-23-2015, 03:59 PM   #1
tjc
tjc's Avatar
67-72-----4x4
when it comes to running gear (transfer case ) were they all the same or was one year better than the other?
Thanks Tom from Iowa.
tjc is offline   Reply With Quote
Old 03-23-2015, 04:06 PM   #2
71swb4x4
71swb4x4's Avatar
Re: 67-72-----4x4
I believe the np205 transfer case was in most 1969's and all 1970-1972's.
The transfer case before that was the Rockwell t221.
In a lot of people opinions the 205 is the superior transfer case.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-23-2015, 04:41 PM   #3
SS Tim
SS Tim's Avatar
Re: 67-72-----4x4
71-72 with the NP205 transfer case and disc brake, open knuckle front axle is probably the best choice.
SS Tim is offline   Reply With Quote
Old 03-23-2015, 05:02 PM   #4
truckster
truckster's Avatar
Re: 67-72-----4x4
I agree. The NP205 is as heavy as a tank, but it's as solid as one too.
And the open knuckles are great. My 72 Blazer turns tighter circles than my 95 Z28.
truckster is offline   Reply With Quote
Old 03-23-2015, 05:52 PM   #5
68350
68350's Avatar
Re: 67-72-----4x4
The 205 in my opinion is the best transfer case they have made. Its basically rock solid and indestructible for most applications.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 03-23-2015, 07:32 PM   #6
57taskforce
All about them K’s
57taskforce's Avatar
Re: 67-72-----4x4
+1 best oe supplied case ever made. Cast iron gear drive bliss I guess the only complaint some have is the not so low, low range but you can't break them.
Tyler
Old 03-23-2015, 08:00 PM   #7
tjc
tjc's Avatar
Re: 67-72-----4x4
can you put the 205 in a 68
Old 03-23-2015, 08:35 PM   #8
CUSTOM/10
CUSTOM/10's Avatar
Re: 67-72-----4x4
Absolutely, but there are different versions. Auto, standard, 1/2 ton, one ton in later model trucks, slip yoke rear in later blazers. You just need to know what you plan on doing and get the correct version for your application ! Also the correct adapter, and 205 crossmember !
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 03-23-2015, 08:46 PM   #9
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: 67-72-----4x4
The all gear rockwell T221 used through 69 is probably just as strong as the np205 but its harder to get parts for.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 03-23-2015, 08:47 PM   #10
Vintage Windmills
Vintage 4x4s
Re: 67-72-----4x4
Just need a SM465 or SM 420 and it will go slower than you can walk!
Old 03-23-2015, 10:54 PM   #11
57taskforce
All about them K’s
Re: 67-72-----4x4
Yes sir that is exactly right. I personally don't have complaints on the 205 low range but know some do, thus the 205/203 doubler. It's low enough for everything I need it to do in stock form.
Tyler
Old 03-24-2015, 10:19 AM   #12
Re: 67-72-----4x4
Absolutely correct. Every year was available with a bulletproof transfer case. Very few had the inferior Dana20, and only in some 3spds, which is also a lame transmission for 4wd application. if you swap, do yourself a favor and get the whole ball of wax. as far as I know only '69 Blazers got the NP205 and '70 was the first year for the full line. All '70s had open knuckle front axle,too. When the axle changed to open knuckle, so did the steering. all this interchanges as well. You can also just as easily swap front end, steering, and transfer case/transmission combos from any later solid axle GM 4wd. 2:1 is as low of gearing I have evr needed. I don't drive on boulders. That's what legs are made for
Old 03-24-2015, 01:47 PM   #13
tjc
tjc's Avatar
Re: 67-72-----4x4
I found a 72 1/2 ton with auto and cast iron transfer case, would that be original to 72
Old 03-24-2015, 02:40 PM   #14
CUSTOM/10
CUSTOM/10's Avatar
Re: 67-72-----4x4
If it's original it would be a TH350 & NP205. If nothing has been changed, and it's a 72 !
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 03-25-2015, 02:23 AM   #15
swamp rat
swamp rat's Avatar
Re: 67-72-----4x4
Just google NP205 (New Process 205) and hit images, you should find plenty of pic's to help you identify. Be aware there is subtle differences in an NP205 and an NP203 on the case.
My 72 is a 350/350 with a NP205, standard equipment.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-25-2015, 07:34 AM   #16
burnin oil
Re: 67-72-----4x4
The 205 is a beast but it is not the strongest. The bearing supports are aluminum so it will flex under a lot of torque. Sled pullers blow the crap out of them. The newer NP271/273 case is a lot stronger than the 205. The 205 is very adequate for most applications though.
burnin oil is offline   Reply With Quote
Old 03-25-2015, 11:58 AM   #17
johnw893
Re: 67-72-----4x4
The rockwell is about the toughest you can get but loud loud (straight cut gears) just don't run them low on oil
johnw893 is offline   Reply With Quote
4x4.
