03-25-2015, 04:01 PM | #1 |
Lifting shortbox truck bed and cab with cherry picker engine hoist
I am wondering what you guys have done to lift your cab on your own with a cherry picker engine hoist? Also wondering if this is possible with the bed? Also while bed is off what simple things are you using to store it on so the bottom sides don't get damaged, or would it be better off to remove the whole box side and set them in the corner?
03-25-2015, 04:14 PM | #2 |
Re: Lifting shortbox truck bed and cab with cherry picker engine hoist
Don't know about the cab, but I did my bed that way. The previous owner installed eyelets that have since been removed, but it sure made the job easier
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
03-25-2015, 04:46 PM | #3 |
for the bed milk crates and 4x4s
for the cab homemade 4x4 dolly with big casters enlist your friends its not worth throwing your back out or worse! Last edited by cv65; 03-25-2015 at 04:50 PM. Reason: help |
03-25-2015, 04:52 PM | #4 |
There are some pics on this site about engine hoist cab lifting.
A couple of weeks ago I made a fixture to lift my LWB bed. Works perfect. Similar in design to a production one below, 1/3 the price. Also made a rolling cart for the bed to rest on while working on the truck. Rolls back over the rear end for storage. No real pic of it though. Barely see it in the pic below. Last edited by Evoracer; 03-25-2015 at 04:59 PM. Reason: add |
03-25-2015, 05:40 PM | #5 |
Check The Champ, Demonstrator
67-72 Google search above " Cab Rotisserie Thoughts"
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
03-25-2015, 05:47 PM | #6 |
Here's how I did it !
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
03-25-2015, 08:16 PM | #7 |
I'd make the parts in red from the pics in posts, 4 and 6 from 2x4s sandwiched together. Why 2x4s? Cheaper than 4x4s and the knots are less likely to line up.
I use "outdoor wood star drive" torx (Lowes/HD) screws that have a sort of self tapping feature and carriage bolts for big stuff. When the jig is no longer needed, run the screws out and save. Reuse the wood. |
03-25-2015, 10:19 PM | #8 | |
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
03-26-2015, 12:56 AM | #9 |
No paved ground makes the engine hoist impossible so I used the tractor. Eyelets in the mounting holes allows easy pick-up with nylon straps.
Projects: 65' Chevy C10 swb (rebuilt chassis) 65' Chevy Panel swb 64' Chevy C30 flatbed "above" 80' C30 "beneath") Parts: 66' GMC 2503 & 65' GMC I1500 |
03-26-2015, 01:19 AM | #10 |
I BUILT MINE SIMILAR TO CUSTON/10 BUT I USED WOOD. WORKS LIKE A CHARM. IT LIFTS HIGH ENOUGH TO SET ON FLAT BED TRAILER. JUST MAKE SURE YOU CREATE A NOTCH FOR THE BOOM OF THE CHERRY PICKER TO REST IN.
03-26-2015, 08:53 AM | #11 |
The lift in post 4 is nice, but won't work on a stepside due to the way they are designed.
03-26-2015, 10:36 AM | #12 |
I copied an old set of camper jacks a buddy of mine has. About $100 if I remember right. Work like a charm. I lift the cab or bed up about a foot and stick some blocks under to keep it up, then set it back down. Then I scoot them out a couple feet on each side and slide 2 4X4's under and pick back up. That way I can either set it down on a dolly or actually drive my trailer under it and set it down on the side boards.
I used my hoist before with a made bracket but like this control better. I put little boat winches from harbor freight on and crank up a few inches then move to the other side. Piece of cake.
"Life is too short to drive a boring vehicle". Later, Wayne Last edited by cooperhw; 03-26-2015 at 10:37 AM. Reason: error |
03-26-2015, 12:53 PM | #13 |
I did mine off and back on by myself, and with glass installed when putting back on. would of been nice to have a helper standing by though.
1961 chevy K10 my build is------------61K10 build |
03-26-2015, 04:45 PM | #14 |
Dang, That Cab Is Purdy.
"Life is too short to drive a boring vehicle". Later, Wayne |
03-26-2015, 05:57 PM | #15 |
03-26-2015, 08:12 PM | #16 |
I used a hoist and straps for my bed. I have a gravel driveway so I got it lifted and drove the tuck out from under it.
66 shorty |
