Old 03-27-2015, 09:22 PM   #51
TJ's Chevy
TJ's Chevy's Avatar
Re: I bought another one!!!
Originally Posted by Ta2Don View Post
Glad it was apparently nothing major
Yep...so far so good. lol
Originally Posted by 66Submarine View Post
Not to rain on your parade or anything, but AFAIK all of the GMC V6's used solid lifters (IMO it didn't sound like a collapsed hydraulic lifter in the clip anyway). I would look into it before I started buying parts and replacing stuff.
Well I'm replacing the head gaskets because it does have a leaky one. And yes these are solid lifter cams which is why they suggested it being a sticky lifter, or some piece of carbon stuck between the valve.
Originally Posted by awbrown View Post
It would be easy to drop something into the cylinder , and that is the noise it would make .. i always blow all the garbage off the area of the plugs before attempting to replace them if it did stop making the noise , then it went through the engine , or it just finally clearanced itself ...
Yeah its a possibility for sure. I'll blow air around the plugs again to make sure all the debris is gone.
Old 03-27-2015, 09:24 PM   #52
dwcardfan
dwcardfan's Avatar
I agree with aw on that. Glad you got it.
dwcardfan is offline   Reply With Quote
Old 03-28-2015, 12:42 AM   #53
66Submarine
66Submarine's Avatar
I saw you said one was leaking coolant, but there's no point replacing a bad head gasket if the engine is toast.
To be honest, I'm not sure how much of an expert they are if they suggested that based on the fact it was a solid lifter. A hydraulic lifter can collapse/bleed down/stick/whatever and make the valvetrain clatter, but a solid lifter obviously can't--there is nothing to compress and create excess clearance. It's hydraulic lifters that are known for issues, not solids.
If it was a valve being held off the seat you should also hear the offending rocker arm tapping from the excess clearance, and you said it wasn't the rocker arm.
Like I said, in the clip it didn't really sound like a lifter to me anyway.
JMO, but I'd still look into it.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 03-28-2015, 10:59 AM   #54
TJ's Chevy
TJ's Chevy's Avatar
Yes one is leaking coolant, but just barely. Its leaking more air out the top than anything but once the engine gets hot enough the coolant bubbles out a little. Nothing major, just a blow gasket. After more inspection I also considered that some crud fell through the plug hole when I put the new plugs in. I blew around the area but its a high possibility I missed some crud and it fell it. I did also look into the cylinder with a flashlight and saw some carbon on the piston so, when I find my darn compression tester I'll do a test and make sure all is OK then if that checks out replace that blown gasket and go from there. Will probably drop the pan and make sure my crank is all good as well. Probably drain the oil again and make sure I don't have any little pieces of metal floating around. Either way we'll fix her up. That'll ol tub ain't gonna stop me from using her! lol
