Old 03-27-2015, 11:53 PM   #1
ADchevys
54 Chevy s10
Been work on this on and off for about a year.
[IMG][/IMG]
Iam using a frame swap kit from code 504, ride tech four link out back, and Thorbecke Brothers arms up front.
[IMG][/IMG]
ADchevys is offline   Reply With Quote
Old 03-28-2015, 09:20 AM   #2
Advanced Design
Advanced Design's Avatar
Re: 54 Chevy s10
Very cool! Keep us updated on progress if you could.
Advanced Design is offline   Reply With Quote
Old 03-28-2015, 09:58 AM   #3
oldman3
oldman3's Avatar
Re: 54 Chevy s10
Looks good, could you show a few more shots of the four bar set-up, near the axle and up front...Jim
oldman3 is offline   Reply With Quote
Old 03-28-2015, 03:44 PM   #4
ADchevys
Re: 54 Chevy s10
Here's a side view of the four link.
[IMG][/IMG]
[IMG][/IMG]
Old 03-28-2015, 11:22 PM   #5
oldman3
oldman3's Avatar
Re: 54 Chevy s10
Thank you...Jim
Old 03-29-2015, 08:02 AM   #6
Sim6
Sim6's Avatar
Re: 54 Chevy s10
Looks good.
Sim6 is offline   Reply With Quote
Old 03-29-2015, 04:42 PM   #7
ADchevys
Re: 54 Chevy s10
Got the front clip mounted.
[IMG][/IMG]
Old 03-29-2015, 05:05 PM   #8
Advanced Design
Re: 54 Chevy s10
Cool, very solid looking truck.
Old 03-29-2015, 08:42 PM   #9
T Hilde
Re: 54 Chevy s10
how well did the core support work out? pics?
T Hilde is offline   Reply With Quote
Old 03-29-2015, 11:18 PM   #10
oldman3
oldman3's Avatar
Re: 54 Chevy s10
Nice...Jim
Old 03-30-2015, 09:12 AM   #11
b.sharp
b.sharp's Avatar
Re: 54 Chevy s10
What size 6cyl is that? I'm trying to figure out if I can put side mounts on my 235? I have holes in the side of the block that look right but a lot different than a 250.
Thanks for the help in advance.
b.sharp is offline   Reply With Quote
Old 03-30-2015, 09:34 AM   #12
ADchevys
Re: 54 Chevy s10
Here's a little back ground, built my first truck when I was 16 with the help of my dad.
[IMG][/IMG]
Built this 50 Chevy six years ago. Been having a blast driving it.
[IMG][/IMG]
it's the green and white one. Here's a picture of my dads truck
[IMG][/IMG]
Old 03-30-2015, 09:35 AM   #13
ADchevys
Re: 54 Chevy s10
It's a 250.
Old 03-30-2015, 01:18 PM   #14
ADchevys
Re: 54 Chevy s10
The core support worked out good, just had to cut it off right below the bottom to holes and bolt it in.
[IMG][/IMG]
[IMG][/IMG]
Old 03-30-2015, 02:17 PM   #15
b.sharp
b.sharp's Avatar
Re: 54 Chevy s10
I have a 235 and I'm not sure you can put side mounts on the block area I'm thinking about using. It doesn not have the reinforced are like the 250 has. It does have the same three bolt hole locations on both side of the block with bolts in them just not sure what they are for.
Old 03-30-2015, 02:20 PM   #16
ADchevys
Re: 54 Chevy s10
I know the 54 Chevy cars used side mounts.
Old 03-30-2015, 04:01 PM   #17
b.sharp
b.sharp's Avatar
Re: 54 Chevy s10
Sorry man, I should have posted that here after seeing that was your truck. So, How far is your cab sitting off the frame? I am making my own mounts and my mounts are going to be about 2 3/4" off the frame in the front. I coudn;t justify buying a premaid kit for what I spent on the truck.
Old 03-30-2015, 04:20 PM   #18
ADchevys
Re: 54 Chevy s10
It sits about 6 3/4 off the frame, it will run a stock style radiator. My white and green truck sits 3 3/4 off the frame, the radiator was a real pain. the kit is very well made, and I put it on with a 4 inch grinder and cordless drill. I did have to modify some of it because it's laying frame.
Old 03-30-2015, 04:38 PM   #19
b.sharp
b.sharp's Avatar
Re: 54 Chevy s10
I do know I have to run a shorter radiator. I hope that is all the trouble I run into. I don't want to tunnel my floor either. I think this is as low as I can go and still stay with a flat floor. I haven't set the cab on the frame yet. Still getting the motor out and working outside makes it a little bit of a challenge. I am also running a T5 behind my 235 with a 2001 olds brevada disk 4x4 rear end. I wish I could see mine sitting like yours is now. I'll get there, but I still have a ways to go. I really like seeing everyoine's pictures. It helps a whole lot and inspires me to keep pushing forward.
Old 03-30-2015, 04:44 PM   #20
ADchevys
Re: 54 Chevy s10
This picture is from my white truck, it has a 3 1/2 inch tunel.
[IMG][/IMG]
Old 03-31-2015, 09:28 AM   #21
b.sharp
b.sharp's Avatar
Re: 54 Chevy s10
how far does it set up off the frame?
Old 03-31-2015, 02:30 PM   #22
ADchevys
Re: 54 Chevy s10
It sits 3 3/4 inches off the frame.
Old 03-31-2015, 03:42 PM   #23
b.sharp
b.sharp's Avatar
Re: 54 Chevy s10
ok. So, my mounts are 3.25 + the rubber bushing. I thought I cut them shorter but I went from 4.25 to 3.25. So I may have to raise a section of my hump to accomodate the T5 shifter hump. I will see when I get everything set into place.
Thanks fo rthe information. It helps to see what others have done.
Old 03-31-2015, 07:28 PM   #24
Sim6
Sim6's Avatar
Re: 54 Chevy s10
Are those 14 or 15 inch steel wheels ADchevy?
Old 03-31-2015, 07:31 PM   #25
ADchevys
Re: 54 Chevy s10
14 inch, came off the s10.
