Old 03-28-2015, 05:15 PM   #1
cerial
cerial's Avatar
292 stovebolt header exhaust issue
I have some stovebolt headers and have some 2.5 couplers. The rest of the exhaust tubing and mufflers I need to get. I am just going alumized tubing for now. I want to run 2.5 to the couplers located by the bellhousing. Then a reducer to 2 inch to the classic mufflers that I can't remember the name of right now to 2 90s that will kick out in front of the tires.
Looking at these headers the opening is 2 inch. I could open up the 2 bolt flange to fit a 2.5 tube if I welded studs on the flange. Or I could just weld the 2.5 right to the flange. Or I could go 2 to 2.5 "reducer" at the flange.
Once the couplers are unscrewed I will be able to pull the engine easily. There won't be any need to touch the doughnut gaskets unless they leak.
How are you guys running 2.5 pipe off of manifolds?
Thanks for any help.
1991 Metro commuter
1991 s10 future project truck
1987 V10 backup daily/junk truck
1985 K20 Winter beater
1991 R30(squarebody) c/c flatbed towrig
1994 s10 80"wb custom build
cerial is offline   Reply With Quote
Old 03-28-2015, 07:11 PM   #2
greg64
greg64's Avatar
Re: 292 stovebolt header exhaust issue
Hey cerial. Don't do what "I" did, which was to weld the pipe to the flanges, and then use flat gaskets to the manifolds. The shop I had make up the exhaust came up with that scheme, and it's leaked ever since.
I talked to Tom Langdon about it and he said not to weld the pipe to the flanges, and to use the donut gaskets that came with the manifolds.
One day, I'll need to redo my exhaust anyway, so then I'll start over with new flanges and gaskets and do it right.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
