Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 03-28-2015, 09:17 PM   #1
65chevysub
65chevysub's Avatar
Power Steering question
I have a couple questions about an issue with my power steering. I got the pump re attached hooked up and filled, but its making a loud whining noise like its low on fluid but is full. I noticed the fluid was frpthy when I checked it . Could the new belt be too tight? It was working fine until about 3 weeks ago when the bolts holding the pump on broke off . I secured it out of the way but left the lines hooked up and drove it that way for about a week. Ineed some ideas as to what the problem could be. The p/s came off of a 72 Chevy truck.
65chevysub is offline   Reply With Quote
Old 03-28-2015, 09:29 PM   #2
pimpston65
pimpston65's Avatar
Re: Power Steering question
does you steering bind? is there enough play in your belt? does the pulley lineup as before?
pimpston65 is offline   Reply With Quote
Old 03-29-2015, 12:29 AM   #3
65chevysub
65chevysub's Avatar
Pulley lines up OK. Belt has a little deflection(maybe 1/2") but seems a little tight, but I don't feel any binding
Old 03-29-2015, 12:32 AM   #4
pimpston65
pimpston65's Avatar
earplugs!!!
Old 03-29-2015, 12:33 AM   #5
pimpston65
pimpston65's Avatar
really im stumped, im sure others will weight in...
Old 03-29-2015, 02:08 AM   #6
LT1 Burb
LT1 Burb's Avatar
If the fluid is frothy it is pumping air, could be air locked somehow.
LT1 Burb is offline   Reply With Quote
Old 03-29-2015, 04:58 AM   #7
padresag
you may have to bleed it. jack the front end off the ground; start it up and turn the steering lock to lock 3 or 4 times. put it down and check it. check the fluid level
ron
padresag is offline   Reply With Quote
Old 03-29-2015, 09:36 AM   #8
65chevysub
65chevysub's Avatar
Ron
I was told there was air in the system as well from a coworker who had the same situation. How does the air get removed? Is it just by turning the wheels?
Old 03-29-2015, 09:48 AM   #9
LT1 Burb
LT1 Burb's Avatar
Ron
Yes
Old 03-29-2015, 02:28 PM   #10
65chevysub
65chevysub's Avatar
Thanks everyone. I'll get this done today
Old 03-29-2015, 03:24 PM   #11
65chevysub
65chevysub's Avatar
Just a quick question. How long does it usually take to get the system free of air? I've only got about an inch and a half of space in the pump and it will overflow and the steering is "jerky" not smooth with front wheels just off the ground. I'been running it on and off for about 2-3 minutes at a time.
Old 03-29-2015, 04:55 PM   #12
LT1 Burb
LT1 Burb's Avatar
You got something wrong, either a bad pump, box or line.
Old 03-29-2015, 05:10 PM   #13
65chevysub
65chevysub's Avatar
Problem resolved! Watched YouTube and the guy on it said to fill reservoir and turn wheel lock to lock 5-6 times with engine off. Then fill and start engine and run lock to lock. I did this 2-3 times and now system is quiet and works like it used to.
Thanks again to everyone
