03-29-2015, 12:58 AM | #1 |
Hood Insulation Ideas? What Do You Use??
I would like to install some hood insulation
The aftermarket suppliers prices I've seen are pretty outrageous -- like $175 plus oversize shipping What are you guys using for underhood insulation? Thanks!! |
03-29-2015, 09:46 AM | #2 |
Re: Hood Insulation Ideas? What Do You Use??
Factory spec.
03-29-2015, 03:46 PM | #3 |
Lowes foil insulation and 3M spray adhesive.
Figure out what you want--then figure out what you are willing to give up to get it. |
03-29-2015, 08:40 PM | #4 |
03-29-2015, 08:47 PM | #5 |
US Army Veteran
I have to ask...what is the advantage to insulating the underside of the hood? I can appreciate cab insulation, but would like to learn the benefit of doing the underside of the hood.
1972 C10 Highlander - The making of a daily driver |
11-07-2016, 08:54 PM | #6 |
Lou, If you don't mind telling me where did you get the Chevrolet radiator support covers?
They look great.
"Every professional was once an amateur who didn't give up" My build 1970 Longbed CST/10 |
11-07-2016, 09:20 PM | #7 |
Old member
BruthaMan,
I've never figured out why you want to hold the heat under the hood either. I have always wanted the heat to get out instead of keeping it in.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-07-2016, 09:26 PM | #8 |
The insulation can help the engine warm up faster, acts as a fire suppressant if it falls down (on newer cars, not sure about these), and muffles engine noise.
On the other hand it also decreases engine cooling.
1968 LWB C20 / AC / Wood Bed |
11-07-2016, 09:28 PM | #9 |
Some cars have insulation to absorb the noise. Maybe keeping the paint cool will help it look good for a longer period of time?
My stock 69 doesn't have any insulation under the hood. It's a base model. I happen to like the sound of the engine, so I have no plans to put any sort of insulation under the hood.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
11-07-2016, 10:03 PM | #10 |
It looks custom when you raise the hood. I'll admit that I added insulation under mine, but its mostly to lower the heat on my fiberglass hood.
11-08-2016, 08:34 AM | #11 |
I see no point, other than protect fiberglass. The sun is the only heat that is hard on hood paint. never had a problem getting an engine to warm up on it's own. The heat comes from within that warms the mass. That's what a thermostat is for. The insulation would only hold heat in that had been created by the engine you wanted to warm up. The ambient temp is created by the object you want to warm up? The ambient temp is created by the warmed up engine. I don't see insulation making the engine too hot, though. The only issue I'd be concerned about is condensation created between hood and insulation being trapped
11-08-2016, 09:15 AM | #12 |
Jim, that's good old LMC. Part # 38-7819 I believe. Its a good product and has held up well. I know LMC gets a bad rap sometimes, but this part has worked nicely.
11-08-2016, 11:28 AM | #13 | ||
"I ain't nobody, dork."
Yup... just the little rubber vibration isolators between the hood skin and the braces. No need for anything else.
Gary
11-08-2016, 01:00 PM | #14 |
Thanks Lou! It is now on the list to buy. Jim
