#276 |
Re: 1957 chevy family truck
Man, your truck is so nice, I keep looking at it!!!
Too bad you smashed your oilpan... Hope you don't have engine damage??
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#277 |
![]() Join Date: Mar 2011
Ouch, hope it's just a pan repair and nothing more...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#278 |
I think its more I notice a slight knock when I put her in the driveway, went for a walk this morning to follow the oil trail and turns out it goes pass were I thought it happen WAY PASS so I may have spun a bearing
#279 |
Thinking I'm going to patch the pan put some oil in her run it see if there's any damage if its good I'll buy new oil pan if not time for new motor
#280 |
Sorry to hear that.
Hope there wasn't any damage to the internals. Kim |
#281 | |
Sounds like you may need a Killer-Cross-Brace under that pan! .... ![]()
My Build: 57 Chevy Pro-Street |
#282 |
The hair line crack cause by looking cool from driving around low
#283 |
The temp fix work ran her and she's not knocking oil pressures good I'm going to raise the motor and tranny up a bit. Guy at the auto parts store suggested cutting off old pan and welding it on the new one like a scrape plate
#284 |
Good to hear you have no further damage!!
#285 |
Great news...Jim
#286 | |
I'm not tail-gating, I'm drafting. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=432758 |
#287 |
Thanx BC was glad to see updates on yours
#288 |
Update oil pan finally fix it was a long few weeks I ordered 1 online took a week ended up with the wrong oil pan so while I dealt with returning that one I ended up just going through jegs she's finally back on the road
#289 |
Glad you're back on the road.
I like the stance. What size tires? How much clearance between the front cross-member and the ground? Thanks |
#290 |
I'm running smaller tires up front there 205 70 15 and 215 75 15 in the rear wrapped around some 1956 chevy wheels. if I had to guess I would say my cross member is about 4 inches off the ground. before I switch the tires the old tires gave it more of a tail dragger look. I miss it but these knew tires offer more clearance up front for steering
#291 |
Kim |
#292 |
Me to I like driving my blazer but I was really missing driving something a little lower plus being in it brings back memories
#293 |
FYI guys I'm running for TOTM if anyone feels like showing some support to the old girl thanx
#294 |
Try a "slam guard oil pan "
1959 apache 1948 chevy coupe http://67-72chevytrucks.com/vboard/s...d.php?t=562949 1964 gmc burban build for pops http://67-72chevytrucks.com/vboard/s...d.php?t=724632 |
#295 |
I ended up raising the motor so next time I run over a beer can going 80 I'm good LOL
#296 |
Even better! Lol
#297 | |
Kim |
#298 |
thanx Kim keep em coming guys we need a 47-59 chevy to win it.
#299 |
Found a,little puddle of trans fluid under my truck so pulled the trans replace the seal to the converter, next day another puddle turns out its the pump seal. So took it in to get fixed only to find out ny trans is a th200. All this time thought it was a th350. $200 to get all the seals replaced on the th200or $700 for a th350
#300 |
Well, that's one lucky thing with the bad luck
![]() I mean prisewise that is....
