Old 03-29-2015, 04:15 PM   #1
biohazardbill
1 ton vs 1/2 ton
I have an older truck (65) that is like a 2 ton truck. I am wanting to convert it from the I-beam front to a control arm setup. Looking at the front crossmember it seems very similar to the 1/2 ton if I remember correctly. I know that these half ton crossmembers are a direct bolt in basically for my year of truck so I was curious as to how different the 1-ton chassis is. Can I just unbolt and swap it like the half ton stuff?
biohazardbill is offline   Reply With Quote
Old 03-30-2015, 07:39 AM   #2
BigBlocksRule
Re: 1 ton vs 1/2 ton
Can't help with the heavy stuff, but I bolted an '85 crossmember to a '62 frame with no issues.
BigBlocksRule is offline   Reply With Quote
Old 03-30-2015, 07:50 AM   #3
burban nate
AFAIK the cross members are the same. All the suspension components are different.
Nate
Current Project: 1990 V3500 CC dually.
burban nate is offline   Reply With Quote
Old 03-30-2015, 08:13 AM   #4
andrewmp6
A 2 ton truck might have a frame way different then a pickups tho.
