Old 03-31-2015, 10:09 AM   #1
73FrankenTruck
73 GMC - power steering issues STILL
73 GMC 3/4ton 2wd, 454, TH400, hydroboost brakes.
PROBLEM: When truck sits more than say 12 hours, power steering assist is either non-existant, or about 50% (if that makes sense). Both scenarios have happened. After I make about 3 or 4 turns, problem is gone. It seems to affect right turns more than left, if that makes any sense, either.
HISTORY: This epic battle started with a pinhole in the hose from booster to steering box. I replaced it. Problem persisted. The power steering pump was kind of whiney, so I put in a new power steering pump and belt. After new pump install, no issues for a week. Steering was amazing. Then this morning, it happened again.
I'm out of ideas. The hydroboost unit is new as well. Am I forgetting something? Any insight or advice would be appreciated.
-C
73FrankenTruck is offline   Reply With Quote
Old 04-04-2015, 11:24 AM   #2
v30crewcab
v30crewcab's Avatar
Re: 73 GMC - power steering issues STILL
sounds like the seals in the box are worn. I've had a few that wouldn't steer cold. once the fluid flows a minute and warms up it will steer.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
