03-31-2015, 06:32 PM | #1 |
NP205 front output yoke bolts
Well, I seemed to have had another senior moment. After rebuilding my NP205 and my front axle and yokes. I can no longer find the 4 yoke-to-yoke bolts that holds them together. In all my research, no one seems to have these in stock or give me measurements. The closest I have come up with is..
Thread .312-24 Thread length 1.43" (1 7/16) Any thoughts Here is a pic of the yoke on the transfer case and axle |
03-31-2015, 06:56 PM | #2 |
Re: NP205 front output yoke bolts
Okay, I have made a positive I.D that they are in fact 5/16 fine grade 8 bolts. Just now need to find the length
03-31-2015, 09:02 PM | #3 |
I can measure one tomorrow
03-31-2015, 09:25 PM | #4 |
I have some 1-1/2" long
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
03-31-2015, 10:49 PM | #5 |
Cut them down if you have to...
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
04-01-2015, 09:05 AM | #6 |
I tried a 1 1/2 bolt but will not let you line up straight to start. Head of bolt touches transfer case collar. Can't cut a grade 8 bolt.
04-01-2015, 08:49 PM | #7 |
Looks to be close to 1 3/8 maybe the 1 7/16 from your first post is correct.
04-01-2015, 08:51 PM | #8 |
You could probably run a nut on and grind the end down to the correct length and then back the nut off to clean the threads up.
04-01-2015, 09:33 PM | #9 |
