how much HP with new intake and carb??
I have a plain jane 350 in my truck and am looking for some ways to get some more power out of it. Right now it has heddman headers with a true dual exhaust and magnaflow xls. I was thinking about a edelbrock intake and carb. What kind should i get and how much Hp would i be looking at gaining. Is there anything else i should do before the intake and carb that would help?
1972 k10 4x4 LWB (Sold in 2005 ![]() |
67-72 Addict!
Maybe 20 Hp, I would Upgrade to HEI with a good tuneup. If you are like most of us seeking more power you will want to upgrade the cam eventually also. My 2 cents....
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
how much $$ am at lookin at for the intake and carb, compared to the Hei setup? Also, later with a cam, what kind of gains am i lookin at there?
![]() Join Date: Apr 2003
I bought an intake and carb (performer rpm intake and a 750 electric choke, and got a free chrome air breather) all as a package deal and i paid right at 450 shipped.
I also bought a accel dist, cap, ignition module and super coil and paid right at 200. Hope this helps you out. David
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
I say that HEI should be your first step. Worry about the intake and carb after you have good spark. My .02
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#6 | |
Formerly yellow72custom
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
Depending on engine combo you have, Heads and such, if this is a run of the mill 350, low Compression engine your best bet for more performance will be Cam & Lifters, Intake & carb on a totally stock motor, maybe 10-12, and my self I would much prefer the QJet carb. The HEI won't really help in adding HP but will help as far as better tunability, Junkyard Distributer should be around 35 - 58 bucks. If these are the stock low compression, everyday cast iron heads, look at a set of either GM Vortec or the GM Fast Burn heads, not real expensive $500 - $600 and these will help, should get a far better rush with these then intake and carb will. For a cam with a little more enthusiasm and keeping a relatively street driving capability try Comp Cams XE 256 or XE262 . Just a not on cam selection it is what you have for the rest of your combination that count on what cam you need. Flat tappet Cam & Lifter kit should think less than $150.
Been there done that. Best bang for my buck was the HEI. It was so much better after that. Then came carb, intake, and finally headers and exhaust. The real difference in power came when I put new heads and a cam. Then she was ready to roll.
If its street driven only and your not trying to turn max rpms then I would look into another set of heads. The HIPO (ya right) 305 heads (casting # 416,601, and one more I can't remember) have 58 cc chambers and will definetly bring it alive. You will probably need to run 89 or better octane but its worth it. You can find these for as little as $50 a set. Add another $30 for a gasket set and your ready. After that I would look at the cam. If and when you decide on a cam stick with something small. Look for a lift figure under .480 and a duration (at .050 lift) no more than 214 degrees. This will give a nice sound and increase power tremendously. It will even help with fuel milage if you usually turn 3000 rpms or so at cruising speed. A stock intake is actually pretty good. A good running quadrajet is a great carb, its better that the holley's and edelbrocks if its tuned and operating correctly. Just my 3 cents on the matter.
thanks for the input yall.
Looks like i will go with the HEI first.
1972 k10 4x4 LWB (Sold in 2005 ![]() Last edited by PureChevy; 02-06-2004 at 10:31 AM. |
