Old 03-31-2015, 11:35 PM   #1
Truck1976
Dually wheel question
My question is I recently acquired a 1976 C30 which had 235/85r16 tires on it but were worn pretty badly. I found some used Toyo 235/85r16 which I had put on the truck. My question is that the tires are only about 1/4" apart at the bottom of the duals when empty will this be a problem? This truck will be used very little but will be used some because it has a nice dump bed on it. Mostly short distances for farm use. Thanks for any help with this.
Truck1976 is offline   Reply With Quote
Old 04-01-2015, 06:07 AM   #2
GM72K10
Next!
GM72K10's Avatar
Re: Dually wheel question
My dually CUCV has 235/85R16s but has spacers between the rear wheels to prevent tire rubbing with a load. My K30 dump has 215/85R16s without spacers. Taller tire, duals do not rub under load.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 04-01-2015, 12:17 PM   #3
Desert1957
Desert1957's Avatar
I had the same issue with my Dually Conversion. I wanted to run the taller 235 tires but they rubbed together with my camper on. I had two new wheels modified to increase the offset, it wasn't cheap but I got the results I wanted.
Center of the wheels could only be moved 3/4" but it was enough to keep the tires from rubbing.
Desert
Desert1957 is offline   Reply With Quote
Old 04-01-2015, 10:56 PM   #4
esbstuff
Rubber rubbing to together equals heat and heat should be avoided at all cost. I have 235's on my dually and they work fine as long as the air pressure is within spec.
esbstuff is offline   Reply With Quote
Old 04-02-2015, 12:11 AM   #5
Truck1976
Thanks for your reply. What spacers did you use? I have heard some bad things about spacers. Thanks
