Old 04-02-2015, 03:03 PM   #1
wildearp
wildearp's Avatar
1965 C10 Uncle's truck
My uncle bought this truck used in 1966 and drove it daily until 1985. In that time frame I did some body work on it and painted it this light blue for him. It sat on blocks outside for several years and then in a barn for a while. I finally got my hands on it to keep it in the family:
Here is where the project is going:
wildearp is offline   Reply With Quote
Old 04-02-2015, 03:03 PM   #2
wildearp
wildearp's Avatar
Re: 1965 C10 Uncle's truck
So far, I have put on the Fatman front end with 2" drop spindles. I filled the firewall holes and removed some of the embossed areas around the heater. I installed the big back window conversion. I am currently working on the rear Fatman universal 4-link. I am awaiting a 9" Ford rear end housing that is being built at a local shop.
This truck will have a 355 Chevy NASCAR SPEC engine with super T-10 4 speed. 9" steel billet posi with 3.89 gears. Strange nodular housing and Strange 31 spline axles. 12" Wilwood brakes with 4 piston calipers all around. Wheels are 16x8 and 18x9.5 American Racing Salt Flat Specials. Howe Aluminum radiator. FanMan 18" electric fan. Bills Brackets. I will run hydroboost with a CPP dual master cylinder with a Wilwood remote distribution/proportioning valve.
This weekend I will set in the engine and trans mounts and add some boxing plates. I already fixed the rot in the front fenders. The hood will have Eddies Motorsport billet hinges.
More pictures to come
Old 04-02-2015, 03:33 PM   #3
4shongo
Nice truck. Looks sharp!
4shongo is offline   Reply With Quote
Old 04-02-2015, 03:51 PM   #4
RockinKees
RockinKees's Avatar
Nice project!
Keep the pictures coming!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 04-02-2015, 04:42 PM   #5
1963c-10
1963c-10's Avatar
Very nice.....cool project
1964 Short bed trailer
Old 04-02-2015, 04:54 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Nice to see it staying in the family!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-02-2015, 05:50 PM   #7
65Gregg
65Gregg's Avatar
First horse I've seen drinking gin, must work you're making great progress. How about some pics of the Fatman front suspension?
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 04-23-2015, 08:16 PM   #8
wildearp
wildearp's Avatar
These were some shots I took when checking clearances:
Old 04-23-2015, 08:24 PM   #9
wildearp
wildearp's Avatar
Here is the Fatman universal 4-link cross member tacked in. I punched it through the frame to get the ride height I needed. There are lots of ways to install this kit. In the end, I changed to Wilwood 12" 4 piston Dynalite brakes from Ford Mustang single piston 10.5" brakes, which allowed me to move the mounting points out 1/2" more than in this photo. Everything is still tacked until my 9" housing comes back from final welding. The front brakes are also changed from 11" GM to the same Wilwoods.
Old 04-29-2015, 08:50 PM   #10
wildearp
wildearp's Avatar
This clears the roadblocks. Full speed ahead on this project. I will retest fit this and measure for a driveshaft. Then comes final welding, c-notch, frame reinforcement, and then some paint. Good things happen after that. Parts are bolted on and stay on!
Old 04-29-2015, 08:56 PM   #11
TJ's Chevy
TJ's Chevy's Avatar
Looks good! Careful on them speed bump now.
Old 04-29-2015, 11:33 PM   #12
wildearp
wildearp's Avatar
My 48 Willys had lower hanging stuff. I am keeping these things in mind, I hope
Old 04-30-2015, 07:48 AM   #13
Lokin4AReason
Lokin4AReason's Avatar
looks like it ll be a fun project ...
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 04-30-2015, 08:09 PM   #14
Monte's62
Wildearp let me first say I love the salt flats. Best looking wheels made IMO. This is gonna be an awesome build with some nice suspension pieces and a killer small block. Reminds me a lot of LVphotos build, really nice. Good luck and I'll be watching.
Monte's62 is offline   Reply With Quote
Old 05-02-2015, 07:33 PM   #15
wildearp
wildearp's Avatar
I hear you. I really didn't want to buy another set because they were already on the wife's car:
I went with the unpolished centers to be a little different. Unfortunately there is no cost savings in that.
Old 05-02-2015, 08:05 PM   #16
wildearp
wildearp's Avatar
Everything looks like it is fitting. Got the housing, third member, and axles plugged together with brakes. Driveshaft was retoobed and balanced same day service. I plan to c-notch it tomorrow and fit the steering u-joints if I have enough time.
Rear sway bar is a new bolt on Hellwig for a 79 Ford 1/2 ton. I also found the fatman QA-1 coil overs all 4 are 10". The 600 pound springs are for the front, not the 225 pound.
Old 05-02-2015, 08:17 PM   #17
lolife99
67-72 parts collector,…
lolife99's Avatar
Very cool!
Keith
Convert to disc brakes.
Old 05-26-2015, 01:43 PM   #18
wildearp
wildearp's Avatar
I will get some more photos up soon. I finished the frame notch and have painted the underbody and frame. Steering is routed. I fired the engine for my first time on Friday night. After the math, I figure this spec motor was run on our local paved 3/8 mile banked oval. It has a Braswell 390 that I freshly rebuilt. With open headers, it won't idle below 1800 rpm and won't run without a bunch of timing advance. I probably won't be able to drive it on the street at all without a cam and carb change.
I put some single chamber flowmasters on it Monday and it did not like them at all. The carb has holes drilled in all four butterflys and has 4 corner idle adjust and air bleeds to add to the full picture.
It is one wicked sounding engine.
I wrestled around for hours setting up the hydraulic throwout spacing and getting the clutch aligned. Those plastic alignment tools are worthless. I am going to have to find a more accurate method. I even used the trans input shaft without the bell housing, but when I tightened the clutch, I couldn't pull out the trans to install the bell. I took a beating that afternoon.
Old 08-14-2015, 03:03 PM   #19
wildearp
wildearp's Avatar
Here are some updates. I changed the cam to a Comp Thumpr series, changed lifters, intake, carb, and now it idles with a nice lope at around 850. I have started on the bodywork, but it has been too hot to work in the shop long.
Old 08-14-2015, 03:05 PM   #20
wildearp
wildearp's Avatar
Old 08-15-2015, 12:00 AM   #21
TJ's Chevy
TJ's Chevy's Avatar
Perrty cool!
Old 08-18-2015, 08:40 PM   #22
mooseknuckles
mooseknuckles's Avatar
nice!
mooseknuckles is offline   Reply With Quote
Old 08-20-2015, 12:08 PM   #23
Justin@EntropyRad
Justin@EntropyRad's Avatar
really diggin this so far!
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 08-20-2015, 12:31 PM   #24
Bomp
Bomp's Avatar
Nice build.
Sub'd
Bomp is offline   Reply With Quote
Old 08-21-2015, 09:44 AM   #25
aggie91
I'm just glad to be here!
aggie91's Avatar
Nice work so far. This is going to be one nice truck!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
