Old 04-03-2015, 08:05 AM   #1
Mystery_man
help no start need to goto work
1972 c20 pickup I have no power at all and hooked up jumpers before wife left to see if it needed a jump. Still nothing. Nothing turns on
Mystery_man is offline   Reply With Quote
Old 04-03-2015, 08:11 AM   #2
Mystery_man
Re: help no start need to goto work
Its a 402 BBC /400 turbo I have no power at all. No lights nothing like the battery is dead but isn't.
Old 04-03-2015, 08:22 AM   #3
bbcmudtruck
Check the ground wire that comes off your battery and make sure it has a good connection to the frame.
bbcmudtruck is offline   Reply With Quote
Old 04-03-2015, 08:30 AM   #4
Mystery_man
Ground wire from bat runs to block and is tight.
Old 04-03-2015, 08:35 AM   #5
bbcmudtruck
Keep checking your connections. Sounds as though you have a bad ground somewhere. What about your hot wire that goes to the starter?
Old 04-03-2015, 08:47 AM   #6
ChevEE
ChevEE's Avatar
I'm trying to remember right off, doesn't the positive wire come off the battery and go to the passenger fender wall to a fuseable link? If so, check that link.
1970 C-10 lwb, 307 V8, THM-400
1998 Camaro Z28, LS1, T-56 6 speed manual (Daily driver)
ChevEE is offline   Reply With Quote
Old 04-03-2015, 08:50 AM   #7
wbc409
I have had this happen to me before. I would put money on the fusible link being bad
wbc409 is offline   Reply With Quote
Old 04-03-2015, 08:51 AM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
That's not a ground wire, it's a fusible link if it comes off the positive post of the battery. You can replace them but first check that there is no short to ground on the wire that comes off the junction block on the fender.
It's the one on the left.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-03-2015, 08:59 AM   #9
cdowns
cdowns's Avatar
Disconnect the two battery cables clean the contacts and hookup the two wires to see if that was the problem
Old 04-03-2015, 04:39 PM   #10
Mystery_man
It was the fusible link. Thank yall for the help. I am late for work, but oh well I get a long weekend now. lol
Mine wasn't visible it was hidden behind the battery.
