04-03-2015, 08:29 PM | #1 |
Which rear view mirror?
I have a 72 and if I'm correct the earlier models used a mirror mounted on the window frame. I currently do not have a mirror mounted (its been on my to do list).
Which mirror do you guys prefer? I've always liked them mounted on the frame and not on the glass. Would it be a big deal to mount an early style mirror on my 72? Mine already has holes that I believe would line up. Thanks.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
04-04-2015, 07:01 AM | #2 |
Re: Which rear view mirror?
On the windshield is correct for 1972, 1972 I s when the changed to windshield federal law BS
!972 K5 Blazer,Highlander,A/C a twin to the one I Had 1972 K/5 Blazer CST Highlander 15YR project 2003 Silverado Crew 2500HD (Daily driver) 1997 Ford focus (Beater) 2003 ford Taurus (student) 2014 Ford Fusion HYB (wife) 2003 Jetta ( Student) |
04-04-2015, 02:04 PM | #3 |
I have a 72 blazer. It has the mirror on the frame. I have often wondered if it maybe came from the factory that way or whether the original owner swapped it. The truck wasn't really messed with so I question if the original owner would have done that.
Any chance this would have been a running change and some 72's left the factory with them on the frame?
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
04-04-2015, 06:31 PM | #4 |
My preference is the 68, more adjustability. I couldn t keep the stock mirror on it, kept fallin' off, after several failed attempts with reglue, I gave up and put the 68 on it
If you want a 67 I may have one laying around, just tell me you want it
04-04-2015, 11:04 PM | #5 |
The glue-on mirror adhesive you buy at the auto parts store is pretty worthless. You have to have a glass guy mount it for you, because they have access to a Loctite product that will really hold it.
I don't see any reason you couldn't mount a 71 or earlier mirror. My preference is for a newer mirror, since I like the map lights and they're not hard to wire in. |
04-04-2015, 11:36 PM | #6 |
Carpe manana
I had a 72 K10 that made use of a 71 mirror with color coded mount...it was done by a PO and didn't look bad. I'd have stuck with a 72 mirror but didn't bother to change it.
04-05-2015, 02:27 AM | #7 |
Well, I'm really tempted to find an older style one. I personally don't like gluing it to my windshield. Can't change it later and could be difficult to remove later.
04-05-2015, 07:25 AM | #8 | |
04-05-2015, 10:39 AM | #9 |
razor blade will remove the glue
04-05-2015, 09:19 PM | #10 |
04-16-2015, 04:36 PM | #11 |
Update...
I picked up a mirror at the swap meet last weekend. Paid $1 for it. Cleaned it up and repainted the cover (someone painted it black over the original red). Unfortunately, the holes I thought were for the mirror weren't, so I drilled some new ones and mounted it. Here is the finished product
04-16-2015, 11:59 PM | #12 |
Same look I have, only my cover is green.unfortunately I paid a lot more than a dollar
04-17-2015, 01:14 AM | #13 |
Don't feel too bad. I just happened to find one when I was looking! I promise it doesn't happen often. Also, when I got it home I spend about 2 hours cleaning, polishing it, and painting it.
