Old 04-07-2015, 07:41 AM   #1
Lowl!f3
Lowl!f3's Avatar
HD rotor & LD rotor measurments
Where are these measurements taken to find out which rotors your looking at?
Is this talking about thickness or edge of the rotor? The bearing opening?
3) Rotors: There are two different widths of rotors available on the 73-87 model trucks.
3.1) HD or Heavy Duty rotors: (1-1/4" wide version) available from 73-87
* These will require matching HD bearings and calipers.
3.2) LD or Light Duty rotors: (1" wide version) available from 81-87.
* These will require matching LD bearings and calipers.
1965 C10 Project
Lowl!f3 is offline   Reply With Quote
Old 04-07-2015, 12:39 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: HD rotor & LD rotor measurments
On a new rotor, these would be the thickness of the rotor face. Now if you have used rotors, there could be enough wear that the thickness could be less than what is listed so it's not as easy. I know the bearings are different sizes but don't know those measurements off the top of my head.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-07-2015, 06:40 PM   #3
Lowl!f3
Lowl!f3's Avatar
Well they are used, so they must be the HD rotors. I didn't get down on the rotor. I just threw a tape on it and it was what looked like close to 1-1/2". So I would say they are definitely over 1" thick.
1965 C10 Project
Old 04-08-2015, 11:06 AM   #4
chevy_mike
chevy_mike's Avatar
Sounds like the HD (thick) rotors.
