Old 04-08-2015, 12:00 AM   #1
chazz
chazz's Avatar
Steering wheel depth
Simple question...I hope. I just bought a 63 step side. It seems to me that the steering wheel is too close, when I sit (I'm average size) in the seat, the wheel is almost in my gut! Its after market, just would like to know the best solution. I'm not looking for original, so after market is OK. Is there a distance I should be concerned with? The wheel on there now is about 6" from base of horn button to rim. THANKS, I look forward to resto/modding this project with plenty of help from here. No comments, the interior is going to change.....lol
chazz is offline   Reply With Quote
Old 04-08-2015, 12:26 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Steering wheel depth
The bezel of the column on mine is right at the dash. And, it was still a little too close, so I made the diameter of the steering wheel smaller to make the dish of the steering wheel shallower (shortened the hub of the wheel).
Are you able to adjust the steering column toward the dash? Does it have a DD steering shaft that you can shorten?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-08-2015, 12:31 AM   #3
chazz
chazz's Avatar
THXS Vin, I'm going to have to look at this more closely. I thought about just changing the wheel, to a newer one that I like, shorter dish, would be an easy fix?
Old 04-08-2015, 01:27 AM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
You could easily change the wheel. The Grant 502 rubber rim wheel 13” in diameter and 3.5” deep:
Mooneyes makes one that is 15” diameter with a 3.5” dish:
Or a vintage Covico wheel is 14.5” diameter and 2 3/8” dish:
Of course there are numerous other styles to choose from.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-08-2015, 09:55 PM   #5
chazz
chazz's Avatar
Thanks guys, I'm going to start with a new wheel and go from there.
Old 04-08-2015, 10:16 PM   #6
Jim53066
Jim53066's Avatar
I bought a copy of the old Cobra steering wheel off ebay, it is 15 inch wheel and has only a 1 3/4 inch dish. (from mounting base to top of wheel wood)
I mounted it on a small (short) adapter. You need an adapter to mount that type wheel to GM column because it is held on with 9 allen type screws. I did have to bend my shifter away from the wheel as there was not enough room for my fingers to pass over it while turning the wheel, but that is a small price to pay for belly room.
I first had an original Corvette wheel from a 58 on there and it has even less dish to it.
NOTE: That is also a 72 tilt column that is pushed forward as far as it would go without rubbing on the dash.
Jim
Jim53066 is offline   Reply With Quote
