Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 03-27-2015, 12:23 PM   #1
Garyhenrich
Blazer chassis under 54 chev pickup?
Is it possible to take a 54 chevy pick up and instead of putting it on a S-10 chassis use a blazer chassis to get IFS 4 wheel drive but keep it lower than stock? I realize it is too short, maybe put the Blazer front clip on a S10 longbed frame...something like that? I am just finishing my S10 conversion on my 48 but a friend would like to take his 54 and set it up for his wife to drive in a hilly showy area, 4x4 is needed and they want a lower stance. has anyone tried it yet?
Garyhenrich is offline   Reply With Quote
Old 03-27-2015, 09:29 PM   #2
dragonball98312
dragonball98312's Avatar
Re: Blazer chassis under 54 chev pickup?
Why does it have to be a blazer? Why not use a 4wd s10 frame?
dragonball98312 is offline   Reply With Quote
Old 03-27-2015, 09:33 PM   #3
Garyhenrich
I suppose that would work, so it would still need 2" spacers up front and a Blazer rear end in the back, right?. Do you know anyone that has done this? Any other complications? Can't use the drop spindles so it would be a couple inches higher than a 2wd...
Old 03-27-2015, 10:46 PM   #4
dragonball98312
4wd blazers and 4wd s10s have the same front suspension and length rear ends. Both are torsion bar front suspension and 2wd drop spindles will not work. Id find a s10 extended cab 4wd and use its frame. Same wheel base as 2wds just with 4wd.
Old 03-27-2015, 11:14 PM   #5
Garyhenrich
Good info, thank you!
Old 04-10-2015, 12:02 PM   #6
Cape Codder
Cape Codder's Avatar
I had a friend do a Blazer frame in his 54 back in the 80's. He used a full size Blazer from the 70's but it sat high.
Cape Codder is offline   Reply With Quote
