#26 |
Re: 67-72 front crossmember VS squarebody
Not that they are easy to come by but makes a guy wonder if the V6 crossmember would hold an LS. If I recall the V6 was only in GMC?
#27 |
![]() Join Date: Dec 2012
The front passenger side of the crossmember wasabout 1/8" high. I seen where another member just cut and bent down the crossmember. I just thought about adding a piece of 1/8" flat stock
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
#28 |
Installed and will need to be welded
#29 |
New it needs to be cleaned up and a7/16" hole drilled in crossmember. Then paint.
#30 |
Mocked up and ready for paint.
#31 | |
Good stuff. So that crossmember would only be in 4x4 gmc v6??? Probably not to many compared to the other configurations
#32 | |
I havent researched it but I dont ever recall a Chevy V6 of this vintage so as to how rare I dunno. |
#33 |
![]() Join Date: Dec 2011
The GMC v6 is hard to get parts for. I found a cotter pin and a rock in 2 of the cylinders, so needless to say the walls were very scored. I would have spent 900+ on custom oversize pistons, so I got an 8.1L out of a 2002 for a steal instead. Thinking of buying the diy4x motor mounts and seeing if this crossmember and mounts will work.
67 GMC K2500. 305D V6, 4 spd, rotted wood bed, and lots of rust!! WTB: Eaton HO 4:10 or 4:11 tapered beaing gearset, or complete 3rd of either style bearing in the 4:10 ratio |
#34 |
I ordered the diy4x Ls motor mounts for the square bodies. I haven't had a chance to see if it would work. Please post up some pictures if you can.
Keep us posted.
#35 |
![]() Join Date: Jan 2009
![]() I had to cut a little off the top on mine. It's from an 84 k10 diesel and its in my 69 k20 frame with a sbc
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
#36 |
Tool Addiction=Money Shortage
Portalaxls, That looks like the crossmember my pickup had. It was originally a 292 straight six
1967 K20 400TBI SM465/NP205 posi front, Detroit locker 4.56 rear |
#37 |
Here is the cross member painted up and sittin in the frame rails.
#38 |
This is front picture. The mounts and crossmember are not bolted in yet. I had to move the crossmember forward than I was expecting. But it clears nicely. I will take pictures when bolted in.
#39 |
Do you think you'll need to modify the right front corner of the crossmember or shim it some more to match the frame rail since you had to move it all forward?
Brett ![]() 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
#40 | |
Not sure what you mean about shimming? are you talking about the crossmember where it sits in the frame rail??? like the area I added the 1/8" plate? Right know I have it about center of the frame and level side to side. I need to check front to back before I can mark and drill the holes.
#41 |
I have to ask, what is this bracket?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
#42 |
Zach that is an Off-Road Design Steering box brace. It is needed on the old frames after years of abuse(my frame front crossmember rivets were loose and I had to replace them with new grade 8 bolt as you can see in the picture.) or if you plan to run a larger tire. Crossover steering would also be good but for me it would be overkill.
Steering brace
#43 | |
#44 |
Well I am going to put a 1" spacer between the crossmember and the pedestals to clear the oil pan in case I need to remove it without removing the motor. If I needs adjust I will post it.
#45 |
Ok so more to come with this 73-87 crossmember idea..... I found a problem when trying to keep the motor in the correct location front to back, side to side it fits great.
A section of the crossmember almost hits the corner of the oil pan where the bolt that holds the crossover wiring under the crank pulley. It will have to be clearance'd. I will try and explain soon.
#46 |
Well I finally got the motor installed with the 73-87 cross member. A little work but got it in.
This picture is where the front driver side pan it.
#47 |
This is the first hole I cut in the crossmember. Still need some clearanceing
#48 |
Front the front
#49 |
This is how much I had to clearance. Now I can even use the factory wiring harness cross over loom. I forgot to take a picture after the motor was installed.
