Old 04-11-2015, 04:54 PM   #26
gabe2000
Re: LS engine swap into 1966 c10; fuel tank install
Originally Posted by russellrox View Post
any pics of the s10 fuel tank installed in a 60-66 frame, and how it all looks done.
no such thing.
I tried 3 different s10 gas tank and dont fit.
gabe2000 is offline   Reply With Quote
Old 04-11-2015, 09:50 PM   #27
GVDobler
GVDobler's Avatar
How do you open the gas cap with 60 psi and not have it knock you over. I'm missing something.
Jon S
1966 GMC Suburban 305 V6
Las Vegas NV
GVDobler is offline   Reply With Quote
Old 04-11-2015, 10:53 PM   #28
chevy_mike
Never Ending Projects
chevy_mike's Avatar
It doesn't pressurize the tank, it is the pressure into the fuel line to the engine. The tank has to be vented anyways.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-12-2015, 02:12 AM   #29
GVDobler
GVDobler's Avatar
Soo, if you send it out at that pressure, the tank vent has to let air in at that same rate, I think. If not vented the pressure could not be kept up, so not being vented enough could cause problems of low pressure. ???
Jon S
Las Vegas NV
Old 04-12-2015, 10:02 AM   #30
66LSx
66LSx's Avatar
Vented gascaps are usually always a good idea... esp if you live in a high temperature change area.
Aka I fill my tank now (45*F) and in 2 weeks it will be 70*F and sunny one day.
doesnt take long.
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 04-12-2015, 10:31 AM   #31
LT1 Burb
LT1 Burb's Avatar
When I did my suburban tank I used the factory Camaro pump and housing, I just cut it off the Camaro tank and welded it onto the suburban tank. That maybe an option, suburban tank with newer Silverado flange and pump., I left my stock suburban fuel sender in for the gauge.
LT1 Burb is offline   Reply With Quote
Old 04-12-2015, 03:40 PM   #32
chevy_mike
chevy_mike's Avatar
Return pressure is typically much less than supply pressure. Volume and pressure is lost because of the fuel used by the engine.
Old 05-30-2015, 01:07 AM   #33
jadedbird
jadedbird's Avatar
Any pics of this tank? Or part number?
jadedbird is offline   Reply With Quote
Old 05-30-2015, 08:36 AM   #34
Gooker928
Originally Posted by Blue666 View Post
You might want to check the diameter of the LS fuel pump compared to a TBI type fuel pump. I think all the fuel injection pumps may have the same mounting ring size, just the installed depth is different.
The older, non EFI senders are a smaller diameter.
Let us know what you find.
Correctomundo........ I had star Dyno in spring branch Texas install a Silverado fuel pump and sending unit in the jeep tank I used. I paid $75 for the tank new and they baffled the tank and installed the fuel pump and sender for $450.
I think Terry said that he had to shorten the depth of the pump.
Gooker928 is offline   Reply With Quote
Old 05-30-2015, 08:40 AM   #35
Gooker928
Originally Posted by jayoldschool View Post
Bring your S10 sender to the parts store, and ask for a 94-96 Caprice LT1 sender and pump. That pump might swap into your sender, or the complete sender might work.
I tried this on a chevelle I did since the caprice tank is a nice replacement in the 70 chevelle. Even the impala SS fuel pump won't produce enough pressure.
Old 05-30-2015, 08:45 AM   #36
Gooker928
Originally Posted by ls60apache View Post
lots of good info here has anyone considered using a pump from the 96 full size truck with the 350 vortec. its pressure specs are inline with the ls engines not sure of volume tho. 96 is the only year that had the replaceable pump that will fit in the s10 hanger. in 97 they went with the module assembly.
That dog won't hunt.... Tried it......
Old 07-29-2015, 08:44 PM   #37
buds56
buds56's Avatar
I was reading through this thread this evening and am thinking about a 19 gallon blazer tank and module ( they are cheap on ebay) for my 61 project.
I did an 98 s10 ls swap last year and the stock pump worked fine for the 5.3
I have an original cluster with the gauges I'd like to use in the truck, but if its not practical I'll upgrade to modern gauges.
I'm curious as to what you all are doing for a fuel gauge, any one using the stock gauge?
If so how is it done?
Thanks, Bud
buds56 is offline   Reply With Quote
Old 07-29-2015, 10:06 PM   #38
65Gregg
65Gregg's Avatar
Tanks inc 53-54 Chevy passenger car, baffled and ready for Tanks supplied pump.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 02-26-2016, 02:28 PM   #39
crakarjax
crakarjax's Avatar
Originally Posted by ram153624 View Post
The 1994 S10 and many other fuel tanks, as Blue666 points out, have intank pumps with sending units that can accept LS pumps (58psi). There are many sources on eBay for these. The filter and pressure regulator I will use is the Wix 33737, used on the '98-'04 Corvette. To make the lines simple, I will use braided stainless steel from Earl's Plumbing with the hose ends that plug into the factory fittings. We must be cautious to use the new hose that will stand up to today's crappy fuel. Remember that these are nothing more than glorified rubber hoses, so check with Earl's to ensure that the hose will last.
I will post pix of the install when I can get out there to work; it is still cold in GA
I forgot to mention that the pump that Potak and Bryant recommend is the Walbro 340, which is readily available on eBay. I haven't ordered mine yet, but the pix indicate that it will be a drop-in deal for the S10 tank.
With the S10 tank, Walbro 340 pump, Wix 33737 FPR/filter, and Earl's lines, this is the most simple and lowbuck setup I can imagine.
2004+ LS setups use a pump that has the regulator and filter built into it. Have you considered using one of those? Do you have pics of how the S10 tank fit, specifically how far below the frame rails does it sit?
How did you mount this, and do you have pics of what it looks like from below and behind?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 02-26-2016, 10:59 PM   #40
65Gregg
65Gregg's Avatar
Lower frame rails were trimmed approx 1/4-1/2 " to allow proper fit.
65Gregg
Blue long bed
White TBSS
61 Impala
Old 02-27-2016, 05:15 PM   #41
crakarjax
crakarjax's Avatar
Looks nice. Is the filler neck going to clear the frame rail?
Old 02-27-2016, 11:39 PM   #42
65Gregg
65Gregg's Avatar
Yep, it fills behind the tail light
65Gregg
Blue long bed
White TBSS
61 Impala
Old 02-27-2016, 11:45 PM   #43
65Gregg
65Gregg's Avatar
Tucks up nice and high, hard to see from behind. I can't take credit for this install, other members pioneered this before me.
65Gregg
Blue long bed
White TBSS
61 Impala
Old 02-29-2016, 08:56 PM   #44
dschmit
Any pictures of how you made your tail light hinge? looks awesome, good work!
dschmit is offline   Reply With Quote
Old 02-29-2016, 09:47 PM   #45
65Gregg
65Gregg's Avatar
This is during mock up on a spare bed corner, a great friend made this for me. I certainly couldn't have done it, LOL.
65Gregg
Blue long bed
White TBSS
61 Impala
Old 02-29-2016, 09:48 PM   #46
65Gregg
65Gregg's Avatar
Another one
65Gregg
Blue long bed
White TBSS
61 Impala
Old 03-01-2016, 12:04 PM   #47
dschmit
Thank you for the pics
Old 03-01-2016, 01:46 PM   #48
crakarjax
crakarjax's Avatar
Whoa how did you get a filler with no cap?
Old 03-01-2016, 11:55 PM   #49
65Gregg
65Gregg's Avatar
Ford Escape filler=no cap.
65Gregg
Blue long bed
White TBSS
61 Impala
Old 03-02-2016, 12:29 AM   #50
60chevyjim
60chevyjim's Avatar
that tail light gas fill is cool !!
60chevyjim is offline   Reply With Quote
