04-12-2015, 09:15 AM | #1 |
AC resistor
any body have any pics of where this mounts....does it need to be grounded?
thanks Jz
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
04-12-2015, 09:55 PM | #2 |
Re: AC resistor
ttt
04-12-2015, 10:06 PM | #3 |
Re: AC resistor
How bout this?
04-12-2015, 10:11 PM | #4 |
Re: AC resistor
thanks but i can't see where is screwed into ... i blew it up in iPhoto jus can't see it thanks
04-12-2015, 11:28 PM | #5 |
Re: AC resistor
The part you are asking about is actually a relay. There is a great reference in post 13 in the thread linked below that was, for obvious reasons, closed. Best to ignore the balance of the thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=216218 |
04-14-2015, 08:00 AM | #6 |
Re: AC resistor
that relay screws to the side of the A/C fiberglass case inside the cab. I'll see if I can find a pic showing it....
Ben |
04-14-2015, 09:39 AM | #7 |
Re: AC resistor
Mine needed to be grounded. If I am not mistaken, it screwed to a piece of sheet metal on the drivers side of the A/C box. I don't know if it was relocated during a previous repair.
BTW reading the posts beyond 13 gave me a chuckle.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 Last edited by Longhorn 70; 04-14-2015 at 09:48 AM. |
04-14-2015, 11:16 AM | #8 |
Re: AC resistor
It screws to the side of the heater core air box (inside cab) on the right side toward the top of the box. Barely enough room to connect the electrical plug connector due to interference with upper cowl dash. use a mirror of feel with your hand to find the two mounting holes.
