04-12-2015, 10:26 PM | #1 |
Need alittle help on power steering brackets
I'm doing a v8 swap on my 67 chevy c10. I put a built 350 in it that I built. I'm try to wrap things up. Having alittle trouble trying to mount my power steering. I got a 71 chevy van power steering with brackets. Try to use the brackets but there not working. How did y'all mount your power steering? If you a got pictrues I wound like to see them. Here's a picture of my engine.
04-12-2015, 10:28 PM | #2 |
Re: Need alittle help on power steering brackets
350
04-14-2015, 08:25 AM | #3 |
well, these trucks that came with power steering, all had the "Short" water pump, you have a "Long" water pump installed on your engine, you will need brackets from a later ('73 on) chevy truck/car in order to make it work. (I had the same issue) the brackets for the alternator is way different, as it bolts to the thermostat housing and there is a lower bracket that bolts to the front of the water pump.the power steering brackets are pretty much the same, some are just a little different, but not by much. here are some bracket pictures, hopefully, you'll have an idea of what's needed....
Ben |
04-14-2015, 10:42 AM | #4 |
ohh so thats what the rear bracket is supposed to lok like! I used a slide bracket from a 68 chevy 250 alternator bracket to adjust my waterpump on my 77 350 with long waterpump.
now i know what to look for what wheels are you using that accept those ceneter caps? steelies right? are the nubs on the inside or outside?
1967custom Last edited by michael bustamante; 04-14-2015 at 10:48 AM. |
