Old 04-13-2015, 02:35 AM   #1
1960chevypanel
Remove PTO winch?
Has anyone removed a PTO driven winch? There's a drive line from the winch back to the trans that has three or four joints on it. How do those joints come apart? Can't see any way to disconnect them... Is there a pin that hammers out or ?
1960chevypanel is offline   Reply With Quote
Old 04-13-2015, 12:41 PM   #2
jtrichard
Re: Remove PTO winch?
with out pics its hard to say but as i am into heavy equipment some PTO type shafts you have to take the U joint apart in place
jtrichard is offline   Reply With Quote
Old 04-13-2015, 09:56 PM   #3
1960chevypanel
Here are some pics
Old 04-14-2015, 01:26 AM   #4
jtrichard
SCRAPE some of the crap off .... looks like a pin near the carrier in first pic and i can see a set screw n the bottom of the joint in the last pic .. the pin could be a (shear pin) made to "shear" off if the unit is over loaded may have cotter pin holding it in remove and tap out "MAYBE"... second pic looks like it WAS a slip joint years ago if so it will have a key-way without any pin or set screw
