85 c2500 suspension on a 66 frame?
So my buddy wants me to do his research. He has the chance to buy a 2wd 85 c2500 with power steering/power brakes (but no brake booster is on the truck)
it's a 14 bolt rear end and 8 lug truck... Used to be a diesel. But was converted to a 350. (And that's why the booster is gone) So will the 85 goodies fit? Also he wants to know if 16" hd rims of. A 04-07 Silverado would fit those axels? thanks in advance |
Re: 85 c2500 suspension on a 66 frame?
diesels did not use boosters for brakes as he diesel produces no no vacuum for the booster so they used a hydroboost setup instead
the 85 stuff will fit. capt fab makes the steering box adaptor and the mounting pads for the rear axle ron |
Well it all depends if the rear is leaf or coil. His truck is also coil. So is there anyways to make a leaf spring rear into a coil spring reart?
I always forget about chevs with their coil springs
look at the rar spring installation in the back of Jon's suburban http://67-72chevytrucks.com/vboard/s...d.php?t=448681 or you can use the spring setup from a gmc capt fab's gives you the ability to mount the axle to a coil spring setup ron |
#6 | |
Did you send the wrong link? He has a leaf spring in that 4x4 burB. but I found this
#7 | |
And this
#8 | |
I had already answered that question before ron |
Ah I was getting it backwards myself.
I can't find the hub bore Size anywhere. Will 03-07 8 lugs fit on a 85 axle? |
