Old 04-14-2015, 12:58 AM   #1
masor
2wd Lift coil springs
1975 C20. Here's the deal. I ordered the Moog 6454 coil springs for the front of my truck to gain about an inch of lift. It was exactly what i wanted! But the only down side is that they are WAY too stiff. I feel every little crack and pebble in the road. The spring rate is between 1000 and 1200 pounds, I forgot.
So my question is, has anyone found a coil spring to use for the front that will retain the height, but have a softer spring rate? I see "Chassis Tech" has coils listed on eBay as "3inch coils for c10, c20, c30" I know all three of these trucks have a different ride height due to different height coils and spring rates. So I don't know how they 3 inches. They don't have the spring rate listed either. Has anyone ever tried these?
Maybe someone out there has adapted a coil spring from a different make or model of truck to work on a 73 - 87 ?
Here's where the truck sits right now so you can see. Any info helps
masor is offline   Reply With Quote
Old 04-14-2015, 05:26 AM   #2
andrewmp6
Re: 2wd Lift coil springs
Chassis tech is another name for airbagit.com they are known for making junk.Your best bet is talk to http://denverspringandsuspension.com/ have them make you a custom set of springs for it.
