04-14-2015, 04:36 AM | #26 |
Re: spark plug choice
04-14-2015, 04:51 AM | #27 | |
http://www.summitracing.com/search/p...20plug%20wires |
04-14-2015, 07:04 AM | #28 | |
If you swap points to HEI, there was a certain year Corvette plug wires that are the correct length to fit our trucks, and they had the correct ends. HTH...don t. ... |
04-14-2015, 09:14 AM | #29 | |
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
04-14-2015, 09:44 AM | #30 |
I will confirm on the 0.035 to 0.045 plug gap. My truck was converted from points to HEI and I couldn't figure out why my truck ran like crap until I checked the gap.
Also had to replace the points resistor wire which is easy enough to do with replacing the wire from the bulkhead. You'll need a new terminal end to do it properly though but then its oem. |
04-14-2015, 08:44 PM | #31 |
0.035" for points. Hei use 0.045" gap. Plugs are your choice. I use R44TS since I do a lot of slow cruising and very little hauling loads in my truck. If you convert to hei it will run a whole lot better.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
