Old 04-14-2015, 05:11 PM   #1
americanmusc1e
americanmusc1e's Avatar
I have an idea for battery relocation and anti-theft
I'm wanting to relocate my battery out of the engine compartment and I had a rather interesting idea that I want input on.
Keep in mind that my truck already has a 26-gallon gas tank mounted in the front of the bed, and it is 4wd with 4" of lift so I have plenty of clearance above my diff.
I want to sink a box in the bed that contains the battery, a heavy-duty relay, a remote control of sorts, and possibly a gps location unit.
The idea is that the battery box will be locked and I will be able to control the relay and all the juice coming out of the battery with a remote control on a key FOB. The truck will do without a traditional key start and use a racecar-inspired push-button starter (with a separate switch for ignition on). I will be bringing a large awg positive cable (considering running it in PVC conduit) to a junction block in the front.
Below is my highly engineered drawing of what I want to do. Has anybody done this before? I've been looking for something mostly pre-fabricated that I can work with. I could fabricate it myself, but I'm slow. Also I wanted to do a proximity key, but there is nothing commercially available even close to what I want to do. With a push-button fob I could probably do it.
I'm welcome to thoughts and considerations.
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 04-14-2015, 05:30 PM   #2
67 cst swb
67 cst swb's Avatar
Re: I have an idea for battery relocation and anti-theft
I have been thinking of a remote activated battery disconnect for awhile. Jhwkns and I bounced some ideas around awhile back, but I guess I never really followed thru with it.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 04-14-2015, 06:10 PM   #3
americanmusc1e
I found this kit to control the battery disconnect. One problem solved!
I'd rather have it done with a proximity key (mostly so I don't forget to disconnect it when I walk away), but I can always work on that later.
http://www.summitracing.com/parts/rfw-ms11/overview/
-- Josh
Old 04-14-2015, 07:21 PM   #4
dibbleg
You could probably dig up a little more info on a RFID switch. A quick google search pulled up a bunch of info about a kill switch for a vehicle.
Chris Mead Tattoos
dibbleg is offline   Reply With Quote
Old 04-14-2015, 11:35 PM   #5
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
My HEI has a kill switch. A remote seems even better.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-18-2015, 03:22 PM   #6
americanmusc1e
So I came up with this.. (see crude drawing at the bottom of this post) which uses a garage door opener button (GDO in the crude diagram) as an effective solution. I texted my boss to see what he thought, and he was just like "Dude! Arduino Nano!" which is a small embedded board programmed in a fork of C that can do all this without all the timers and hard logic.
So I ordered this http://www.ebay.com/itm/271826329538 and I can already program well enough to do the programming. Now I just need a oil pressure switch.
The basic logic is this:
- everything but the oil pressure switch is locked in a battery box
-System is armed with some sort of momentary switch (fired by a garage door opener/RFID reader of something) --> MASSIVE relay is turned on sending power out of the battery box
-System will stay armed for 3 mins. If the engine isn't started (oil pressure switch closed) in 3mins. The entire system disarms and the MASSIVE relay closes until it is rearmed
- If the oil pressure switch opens (say the engine stalls) I have 30 seconds which to close the oil pressure switch (start the engine) before the system disarms. This is a safety feature in case I stall in traffic or something
EDIT - some of the complexity of this system is from the fact that I do not want someone bypassing the oil pressure switch to be able to arm the system.
-- Josh
Old 04-18-2015, 03:44 PM   #7
americanmusc1e
For anyone following along..
Because the arduino swiches up to 40milliamps of 5v and I need to actually switch several hundred amps at 12v I will need a series of relays.
This little guy http://www.ebay.com/itm/131394111558 will step me up to several amps of 12v DC.
And I may use another bosch-style automotive relay to get enough current to pull the coil on my main relay. I'm still looking into how much amperage I'll need for it.
EDIT-- I think something like this will work for my main relay http://www.ebay.com/itm/500-AMP-Batt...item462b00e68e
-- Josh
