Old 04-14-2015, 10:05 PM   #1
blown&0chevelle
lighting issues on 69 c10
im going nuts here. I have an issue with rear turn signals and brake light not working. Everytime I turned lights on the tail lights would illuminate as well as turn signals. I just replaced all bulbs in truck and now my headlights stopped working as well as my windshield wipers and dash lights what is going on. thanks.
blown&0chevelle is offline   Reply With Quote
Old 04-14-2015, 10:27 PM   #2
EARNHARDT#3
EARNHARDT#3's Avatar
Re: lighting issues on 69 c10
See the advice I gave a few posts down......
http://67-72chevytrucks.com/vboard/s...d.php?t=667215
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 04-14-2015, 10:31 PM   #3
blown&0chevelle
I have the ground wire attached at dash and replaced headlight switch. I assume its a ground issue just don't know how to correct it.
Old 04-14-2015, 10:44 PM   #4
leftybass209
leftybass209's Avatar
Did you purchase the correct bulbs? Taillights should be 1157 and have 2 filaments, and the backup lamps should be 1156 and have a single filament. Also, the turn signals in the front should be single filament 1156's as well. If you mix and match bulbs, funky things happen. Also, do you happen to have LED lights anywhere on the truck? I would re-check your grounds, wire brush some clean connection locations.
leftybass209 is offline   Reply With Quote
