Old 04-14-2015, 10:33 PM   #1
HBlue
Gear Shift problem
I have a 76 Custome Deluxe with the 350 Automatic Trans.
What would cause the gear shift to not lock into place?
When I shift from Park to Drive, it does not go into gear.
I have to go to 2 or 1 for it to go into gear, then go back up to N and back down to Drive.
When I shift from D to R, I have to go nearly to P for it to go into reverse.
It just started this a couple of days ago. Is there some linkage I need to adjust.
thanks for your help.
HBlue is offline   Reply With Quote
Old 04-14-2015, 11:28 PM   #2
lilpoindexter
lilpoindexter's Avatar
Re: Gear Shift problem
Detents in the shifter worn, or linkage worn.
lilpoindexter is offline   Reply With Quote
Old 04-15-2015, 07:35 AM   #3
Keith Seymore
Keith Seymore's Avatar
I would guess the linkage got out of adjustment.
Other than Park the actual detents are in the transmission itself. There is a cantilvered spring which engages a "roostercomb", and that's what gives you the "feel".
Take a look under the truck. You should see a rod that goes down from the steering column to the trans. There's a little "barrel" attachment with a bolt on it.
Chock your wheels so the truck doesn't roll. Put the shifter in "N"; go under the truck and loosen that barrel; click the trans lever around until the trans itself is firmly in neutral. Tighten the barrel bolt back up.
If that doesn't do it then I would guess something has happened to the spring/roostercomb arrangement inside the trans. Or may e something happened to the cross shaft at the frame, like the spring broke or the half spherical plastic washer fell out.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-15-2015, 09:38 PM   #4
HBlue
thanks for the suggestions.
Everything outside looks fine and is tight.
I tried what you said and it did not help, so it must be the spring/roostercomb.
what's next? Can I drop the pan and replace some parts?
Old 04-16-2015, 08:09 AM   #5
Keith Seymore
Yes. You can drop the pan and have a look.
K
1979-1986
1986 - 2019
