Z06 Manifolds on truck 5.3, will it work?
Hi all,
I am thinking about buying Z06 manifold to put on my truck 5.3, what are the pro and cons and will they actually work? I used DD slider mounts for engine. ![]() Thanks for any help! |
meowMEOWmeowMEOW
Re: Z06 Manifolds on truck 5.3, will it work?
Those will exit directly into the base of the engine perch. To fit one of these swaps, you need it to hug the block and sweep back as fast as possible. The exact clearance will vary slightly with the DD mounts, but the engine perch will still more than likely interfere. Compare that to the general shape of the TBSS, Fbody, or Swap longtubes.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Hi Br3w,
Thanks for your help. I am planning on redoing my exhaust and I have the stock truck manifolds on there, saw these for only $80 a pair. The drivers truck manifold kicks out at an angle towards my frame making an extreme angle back to meet the rest of the exhaust piping in the normal spot. I see the TBSS right side manifolds are out of stock but I hear the hummer manifold will fit just as good as the TBSS? I guess I can wait and keep looking. Thanks again for your response. |
Those look like they might work well on a 4wd
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
meowMEOWmeowMEOW
If you had a crossmember with tubular perches, I think it could be made to work.
Ben- the TBSS manifolds are definately cheaper used if you can find them. I havent' had much access to any Hummer H3-Alphas, which were the only ones that got the 5.3 I've heard that the setup thats running in the new-gen Colorado's might also fit, but parts aren't cheap yet as they haven't ended up in junkyards.
![]() Join Date: Jul 2009
![]() Join Date: Apr 2005
+1
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Cool, thanks guys!
They aren't as cheap as the TBSS manifolds used to be, but they fit well and exit straight down with a two bolt flange. I'm using them.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
Hi all,
What about 2011 corvette manifolds? I found them for a good price if they will fit. Never mind, I just saw the hole in both manifolds that would need covered.
The holes in those manifolds are actually for the oxygen sensors, and even if you didn't put the oxygen sensors there you can plug the hole with a oxygen sensor plug. The angles on those flanges look like they'd work really well.
meowMEOWmeowMEOW
You might have to make a pretty tight bend right off that flange to clear the framerail, but I'd have to see it mocked up to know if it was practical.
Practicality aside, those look like they'd be an interesting base for a turbo manifold. Who wants to cut an adapter for a t4 flange and slap a pair of escargots on em?
Looks like I will jsut wait till some 5th gen camaro ones come up. Well, some have come up but they want $300 for the exhaust manifolds and the cats, I don't need the cats. What would be a good price to offer?
Hey man if you are using dirty dingos and you want to go long tubes go to http://www.schoenfeldheaders.com/ .Call them before ordering and tell them you have dirty dingo mounts .They built their long tube headers around the dirty dingo mounts and they are a made in usa company. Both Brent at dirty dingo and the folks over at Schoenfeld can confirm this for you. I ended up getting the ebay ones that Brent told me that would fit 73-87 on ebay made in china. 200 for the ebay ones compared to the 400 schoenfelds , not bad tho would like to try those long tubes they make.keep us updated
| Bookmarks |
| Thread Tools | |
| Display Modes | |
