Old 02-07-2004, 02:25 AM   #1
taser
k5 drums to disc question
hey all, i got a 73 4wd dana 44 disc brake front end, and was wondering if i can just pull off the hub assemblies and backing plate to stick on the disc setup, or do i have to go from ball joints out with the new setup??
thanks in advance
taser is offline   Reply With Quote
Old 02-07-2004, 02:53 AM   #2
1969 GMC
1969 GMC's Avatar
you could use the whole axle, it is larger diameter and stronger, but you would need new u-bolts.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-07-2004, 10:46 AM   #3
Blazer1970
Blazer1970's Avatar
I'm pretty sure that you will have to swap the spindles also. They changed the bearings so the newer hubs will not fit on the old spindles. I would swap in the whole axle assembly if the gear ratio happens to be the same. The '73 axle will also have 297 series u-joints in the axle shafts instead of small 260 series in the older axle. You might be able to just swap the shafts into your old housing, but I have heard of some people having some clearance problems getting them in. It is easy to swap the shafts once you have the spindles off anyway, they just pull out. It is also a good opportunity to put new u-joints in the axle shafts.
Blazer1970 is offline   Reply With Quote
Old 02-07-2004, 01:40 PM   #4
taser
thx guys, that's what i needed to know. i wish i could just swap the entire axle, but they have 3.07 in them, and i want to stick w/ the 3.73's. hopefully everything goes smooth.
thx -todd
71 blazer 700r4 350 edelbrock cam, 1407 carb, holley intake, hei accel dist
