04-17-2015, 06:02 PM | #1 |
Side mount spare tire mount measurement?
Can someone give me the measurement between the stake pocket and the bracket that the tire mount attaches to? I drill tomorrow. Thanks, Jim |
04-20-2015, 09:53 AM | #2 |
Re: Side mount spare tire mount measurement?
I can get some measurements for you tonight. The rod coming through the hole on the fender should be centered though.
Heres a good diagram also... And a good thread on the fender mounted spares: http://67-72chevytrucks.com/vboard/s...=505728&page=7
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 04-20-2015 at 10:03 AM. |
04-20-2015, 10:05 AM | #3 | |
04-20-2015, 10:11 AM | #4 |
Yeah, I didn't get it with mine either. Piece of 1/4" thick flat bar about an 1" wide should do the trick if you opt to add it. I never went back and added it to mine. Mines been installed since 2009 and I haven't had any issues.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-20-2015, 10:59 AM | #5 |
I LITERALLY just set mine on...leveled it and bolted it down without measuring. lol I can easily fit a 31 or eve 32 inch tire on there if I want. With the hole in the fender adjusting can only go so far so its actually kinda hard to mess up. lol In a way.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
04-23-2015, 08:10 AM | #6 |
It you butt up against the inner edge of the stake pocket to the center of the bolt hole on the mount I have 6".
04-23-2015, 08:14 AM | #7 |
04-23-2015, 08:57 AM | #8 |
Helps to have a second hand.....what I did when I did my conversion was to get the mount where I wanted it. Then I marked all the holes with a black sharpie. Removed the mount, drilled all the holes, then reassembled. I did remove the driver side rear fender to drill the inner mount holes.
