Old 04-18-2015, 09:11 AM   #1
jmader
jmader's Avatar
Looking for a 1967 4x4 Upper Radiator Hose
I'm not having much luck finding a formed rad hose for a V8 engine. Does anyone make one for a 67? What was original from the factory was there a metal radiator tube of was it a rubber hose? Any input would be greatly appreciated.
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 04-18-2015, 10:50 AM   #2
Swar
Swar's Avatar
Re: Looking for a 1967 4x4 Upper Radiator Hose
Did you check LMC? If you can't find one, you can get a universal one that bends wherever you need it to.
Swar is offline   Reply With Quote
Old 04-18-2015, 11:10 AM   #3
jmader
jmader's Avatar
LMC lists one for 67-72 4X4 but I'm sure it's actually only for 68-72. My 67 has an oil filler tube on the intake so the thermostat housing shoots straight forward instead of at an angle. I've seen the flexible ones but am trying to restore it to original so am hoping to find one that is molded.
1967 Chevy SWB K10
Build thread-
Old 04-18-2015, 04:01 PM   #4
SS Tim
SS Tim's Avatar
Give Wes a call. His is listed as a 68-72 but you never know.
http://www.classicheartbeat.com/cata...tor%20Hose.htm
http://67-72chevytrucks.com/vboard/s...d.php?t=649425
SS Tim is offline   Reply With Quote
Old 04-19-2015, 10:51 AM   #5
jmader
jmader's Avatar
Thanks for the links I will check that one out.
1967 Chevy SWB K10
Build thread-
Old 04-22-2015, 07:57 AM   #6
jmader
jmader's Avatar
Top
1967 Chevy SWB K10
Build thread-
Old 04-22-2015, 10:08 AM   #7
67 cst swb
67 cst swb's Avatar
Dayco lists a 70935 as a formed upper rad hose.
But, the buyers guide lists that it fits:
67, 70-71, 73-79 K10, K20 models
So that doesn't appear to be a good match.
If you have a local parts store that sells Dayco, maybe you could go take a look at it.
EDIT: A Gates 20543 is a 2wd application upper hose that looks correct as far as the shape and direction.
Which brings up the question... Didn't all 4x4 have the metal tube for an upper radiator hose?
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 04-22-2015, 10:40 AM   #8
CUSTOM/10
CUSTOM/10's Avatar
Here's a link to a board member that makes them. I believe they came on all 67-72 4x4 trucks, but I'm not 100% sure if 67-68 did or not !
Gary
http://67-72chevytrucks.com/vboard/s...+radiator+pipe
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 04-25-2015, 10:04 AM   #9
jmader
jmader's Avatar
Top
1967 Chevy SWB K10
Build thread-
Old 05-03-2015, 09:14 AM   #10
jmader
jmader's Avatar
Top
1967 Chevy SWB K10
Build thread-
Old 05-11-2015, 07:36 AM   #11
jmader
jmader's Avatar
Ttt
1967 Chevy SWB K10
Build thread-
Old 05-11-2015, 08:05 AM   #12
stacerbob
BODY SHOP SUPPLIES INC.
stacerbob's Avatar
The 69 I just got has metal upper for what it's worth.
stacerbob is offline   Reply With Quote
Old 05-11-2015, 08:22 AM   #13
71swb4x4
71swb4x4's Avatar
Have you looked at this one yet? http://67-72chevytrucks.com/vboard/s...d.php?t=649425
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-11-2015, 08:42 AM   #14
Bigdav160
Bigdav160's Avatar
That link doesn't help. On a '67 intake, the oil fill tube is in the way.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-11-2015, 09:46 AM   #15
...and he is restoring, which means he wants it as it was originally built.
The earliest SBCs had vertical radiators with center outlet, so the neck pointed stright forward. I've seen in '60s car applications, when radiators got side tanks, with angled neck that shoots past the oil fill, like this picture. I think it's the same neck:
http://www.google.com/imgres?imgurl=...d=0CC0QMygMMAw
Here is an older truck picture for reference. I'm thinking you would have a pipe:
http://www.google.com/url?sa=i&rct=j...31438204664787
Old 05-12-2015, 07:50 AM   #16
jmader
jmader's Avatar
Thank you for the pictures. That's exactly what I need. It looks like I will have to build something like the second pic. I might be able to run an angled thermostat housing with one of Wes's molded radiator hoses but I am still hoping to run the original style.
1967 Chevy SWB K10
Build thread-
Old 08-25-2015, 05:19 PM   #17
jmader
jmader's Avatar
Bump.
1967 Chevy SWB K10
Build thread-
Old 08-25-2015, 06:02 PM   #18
jmader
jmader's Avatar
Anyone know if this part might possibly work? Didn't the 60-66 V8's all have the oil filler tube on the intake manifold?
http://www.classicparts.com/1960-66-.../#.VdzlfPluOSo
1967 Chevy SWB K10
Build thread-
Old 08-25-2015, 06:47 PM   #19
john
member #16
john's Avatar
Here's a pic of a 1966.
john is offline   Reply With Quote
Old 08-25-2015, 07:30 PM   #20
jmader
jmader's Avatar
Thanks for the picture. I forgot that the radiator on the 60-66's is smaller than the 67-72 so the link I posted won't work without some modification.
1967 Chevy SWB K10
Build thread-
Old 08-25-2015, 09:28 PM   #21
shortbed67
I have a small block 67 C10 with the engine in the 4X4 position. I found that a Gates 20868 hose fits perfectly.
67 shortwide
283/350
ps,pdb,ac
no paint
shortbed67 is offline   Reply With Quote
