Old 04-19-2015, 01:19 PM   #1
68 Terry gmc
rockwell t221 transfercase coupler needed badly
Does anyone know where I can get the coupler that goes in the t-case adapter on a Rockwell t221?
68 Terry gmc is offline   Reply With Quote
Old 04-20-2015, 02:18 AM   #2
andrewmp6
Re: rockwell t221 transfercase coupler needed badly
Used will be your only hope,Pretty much no one makes any replacement parts for those t cases.
Old 04-20-2015, 05:26 AM   #3
snj8198
snj8198's Avatar
I had a few more links bookmarked but I see they are no longer active. Sad, we're loosing out drive train suppliers. Here's a couple anyway. May need to keep an eye out for used as stated. Good luck.
http://quad4x4.com/index.htm
http://www.tbtrans.com/transfer_case.htm#chevy_parts
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 04-20-2015, 08:41 PM   #4
68 Terry gmc
Thanks guys
Old 05-09-2015, 09:41 PM   #5
60sIron
60sIron's Avatar
Don't know if you found what you needed or if this will even help. My coupler was warn to the point that the seals would no longer seal and 90w would leak into the adapter. Yes there was slop but it still worked and it could not be replaced. The major issue was 90w on everything. The fix. I made gaskets for each side of the adapter and drilled a taped the weep hole in the bottom. This worked until I found a 205.
60sIron is offline   Reply With Quote
Old 05-12-2015, 01:36 PM   #6
jordanblea
I might have one from when I swapped from the 221 to the 205. Let me check tomorrow.
It had to be done.
jordanblea is offline   Reply With Quote
Old 05-13-2015, 02:53 PM   #7
BLT gmc
68 Terry gmc had two very similar posts on 4/19 within a couple of hours. In the other thread we discussed using a NP 205 coupler. It had to be shortened to 3 3/8th inches, the internal teeth had to be machined to match the T221 coupler and a new seal with larger internal diameter had to be used. The National Seal # is 40071s (thank you to Vero 67). I am pretty sure this is the way Terry was going. Jordan I mention this- One,save you digging and two, it may help someone keep their Rockwell rolling without finding the elusive coupler. Bruce
BLT gmc is offline   Reply With Quote
Old 05-13-2015, 05:42 PM   #8
jordanblea
I didn't catch the other thread, sorry!! Anyways I have the coupler if it is still needed. Also have the adapter.
It had to be done.
