Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 04-19-2015, 02:08 PM   #1
FamilyBowTie
89 s10 cab removal?
I am getting ready to remove the cab off my 89. Just want to check here to make sure I have the following disconnected.
Master brake lines
brake pedal assembly and throttle cable
parking brake cable
steering column
its an automatic so anything else I am forgetting?
49 5 window on s10
http://67-72chevytrucks.com/vboard/s...d.php?t=671706
FamilyBowTie is offline   Reply With Quote
Old 04-25-2015, 12:03 PM   #2
hugger6933
Re: 89 s10 cab removal?
Front wiring and engine wiring, I use to take them loose at the firewall where they go into the fuse box, it may require some of the gunk [sealer ] around the bulkhead block to be removed but once you do, you can take all of the wiring loose there. The big part pushs through like it would be going to the firewall after it is unplugged to separate the wires
hugger6933 is offline   Reply With Quote
