Old 04-19-2015, 05:51 PM   #1
pimpston65
pimpston65's Avatar
What the €¥#%
so mocking up my 292, i had to remove the passenger side frame mount cuz this beast came with a 250. no problem there, my issues is now that its moved only the drivers side fits perfect. the passenger side seems like the mount in too far out about 2". i have a plan to make it fit by cutting the back of the mount 2" and while keeping enough material to make the wings that mount to to frame. any ideas that have worked is NEEDED!!!
pimpston65 is offline   Reply With Quote
Old 04-19-2015, 05:56 PM   #2
pimpston65
pimpston65's Avatar
Re: What the €¥#%
driver side all bolted up...
Old 04-19-2015, 05:57 PM   #3
pimpston65
pimpston65's Avatar
Re: What the €¥#%
sitting purrty, just need the other side to bolt up!!!
Old 04-19-2015, 06:00 PM   #4
pimpston65
pimpston65's Avatar
Re: What the €¥#%
this is with the engine sitting how it should, no tension on the hoist chain!!!
Old 04-19-2015, 06:47 PM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: What the €¥#%
this might help?
http://67-72chevytrucks.com/vboard/s...d.php?t=552399
and areotruk has some as well....
http://67-72chevytrucks.com/vboard/s...d.php?t=397681
Old 04-19-2015, 07:21 PM   #6
pimpston65
pimpston65's Avatar
Re: What the €¥#%
Originally Posted by jonzcustomshop View Post
naw, the engine mounts are golden, i have the spacers. it all lines up with me moving the frame side mount, its just too far out!!! i gonna make a cardboard template of the original frame side mount minus 2" if it works i will cut up the mount!!!
Old 04-19-2015, 07:24 PM   #7
Warrens69GMC
Warrens69GMC's Avatar
Re: What the €¥#%
Doesn't the 292 use a special mount/bracket the 250 doesn't use? I believe it does.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 04-19-2015, 07:31 PM   #8
pimpston65
pimpston65's Avatar
Re: What the €¥#%
here's a rough idea, ima make the exact piece outta cardboard to make sure!!!
Old 04-19-2015, 07:38 PM   #9
pimpston65
pimpston65's Avatar
Re: What the €¥#%
i have the correct brackets, unless GM of canada threw me a curve ball!!!
Old 04-19-2015, 10:17 PM   #10
60-66
60-66's Avatar
Re: What the €¥#%
The frame bracket that you removed , did you just move it to the new location ? Or did you find a 4x4 292 frame bracket for the pass side ?
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 04-19-2015, 10:25 PM   #11
pimpston65
pimpston65's Avatar
Re: What the €¥#%
i did move the frame side mount, i also have the 292 mounts also. is there a different 4x4 292 passenger mount?
Old 04-19-2015, 10:27 PM   #12
pimpston65
pimpston65's Avatar
Re: What the €¥#%
pic 4 shows the passenger side, its like its too for out and won't allow the block to move down any further. thats why i want to modify the frame side bracket to pull it back 2"...
Old 04-19-2015, 10:36 PM   #13
60-66
60-66's Avatar
Re: What the €¥#%
That's what I'm getting at . The one riveted to the frame on the passenger side is 4x4 292 only and in a different location as you already know.
Old 04-19-2015, 10:50 PM   #14
pimpston65
pimpston65's Avatar
Re: What the €¥#%
so i do need to cut it down to make it work?
Old 04-19-2015, 10:54 PM   #15
60-66
60-66's Avatar
Re: What the €¥#%
If you need a picture or measurement my 4x4 panel is easy to get at
Old 04-19-2015, 10:54 PM   #16
pimpston65
pimpston65's Avatar
Re: What the €¥#%
heres a pic looking down, you can see the frame side mount lines up. its just too close to the engine!!!
Old 04-19-2015, 10:56 PM   #17
pimpston65
pimpston65's Avatar
Re: What the €¥#%
oh yes sir, i do need all the help i can get!!!!!!!!!!
Old 04-19-2015, 10:57 PM   #18
60-66
60-66's Avatar
Re: What the €¥#%
Old 04-19-2015, 11:02 PM   #19
60-66
60-66's Avatar
Re: What the €¥#%
heres the part numbers for just the riveted frame mount .
Old 04-19-2015, 11:02 PM   #20
pimpston65
pimpston65's Avatar
Re: What the €¥#%
awesome, if you could measure from the part of the frame bracket that touch the frame out to the edge where it meets the rubber mount if the measures the same then somethings wrong on my setup. if yours is shorter then i need to cut mine...
Old 04-19-2015, 11:06 PM   #21
pimpston65
pimpston65's Avatar
Re: What the €¥#%
3 different mounts!!!!!!!!!!!!!!, i feeling like calling GM from 1966 and give em an ear full....
Old 04-20-2015, 10:53 AM   #22
60-66
60-66's Avatar
Re: What the €¥#%
Actually , two rights one for 292 and one for 230-250 and V8 . The third is drivers side all. Heres what I took today if it helps at all. Might want to just try and locate one, with your picking skills it should be easy .
3 9/16 to bottom lip. If the engine were out I could get better measurements . Might contact padreseg , he had one for Aerotruk .
Old 04-20-2015, 11:05 AM   #23
pimpston65
pimpston65's Avatar
Re: What the €¥#%
thats makes all the sense in the world, so i asked the right person!!! my bracket was meant for a 250 and wont fit a 292 unless it came with it!!! thks i will modify mine...
Old 04-20-2015, 11:07 AM   #24
pimpston65
pimpston65's Avatar
Re: What the €¥#%
the notch is at about 3-1/4" and your mark is about 5-1/4" so my estimate was right to take out 2"...
Old 04-20-2015, 01:00 PM   #25
60-66
60-66's Avatar
Re: What the €¥#%
Run a level across the frame rails , then level the engine off the carb flange to get your location right before welding , just a thought
