Old 04-22-2015, 10:41 PM   #1
primetime
primetime's Avatar
draft shafts in 5.3 oilpan
I have a Saab 9-7x with the 5.3v8 & awd. I plan to swap the engine, trans, and computer into my 68 c10. The drive shafts passing through the engine oilpan made me pause in my tracts though. Is it as simple as buying a new oilpan or do I need to try a different 5.3 ls?
1977 Chevy nova (first car/ first love)
1975 Chevy squarebody shortbed
07 Suzuki M109R
primetime is offline   Reply With Quote
Old 04-22-2015, 10:55 PM   #2
marvgarr68
marvgarr68's Avatar
Re: draft shafts in 5.3 oilpan
You can just change the pan and pickup tube.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 04-22-2015, 11:03 PM   #3
crazy longhorn
Fabricate till you "puke"
GMPP hotrod pan (hummer) .....around $150, through Summit or Jegs. Complete with tray ,gasket ,pick up tube,o -ring & the proper dip stick & tube . Smokin deal...longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-22-2015, 11:04 PM   #4
clinebarger
The 4L60E will have to torn half way down for a 2wd output shaft installation & Tail housing.
clinebarger is offline   Reply With Quote
Old 04-23-2015, 10:30 AM   #5
primetime
primetime's Avatar
I didn't realize the transmission was going to be trouble too. Thanks for the heads up.
