Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-23-2015, 10:43 AM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
35 spline
Looking at moving my current 31 spline set up to the Blue Luv and building a new housing for the Yellow truck . I was going 35 spline and 5/8's drive lugs . Should i just go 40 spline ? Is it worth the added weight ?
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 04-23-2015, 12:32 PM   #2
71Dragtruck
71Dragtruck's Avatar
Re: 35 spline
Could go 40 gun drilled, I have 35 moser in mine and so far so good.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 04-23-2015, 02:59 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
Re: 35 spline
Not sure of other manufacturers, but when I went from MW solid 35 spline to their 40 spline gun-drilled axles in the early '90s, the 40 spline axles weighed 4.5 pounds less in my application.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-24-2015, 01:49 AM   #4
moggey01
Re: 35 spline
I have 35 spline gun drilled and a star flange. Used a posi unit and that is the biggest axle I could use.
moggey01 is offline   Reply With Quote
Old 04-24-2015, 10:22 AM   #5
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 35 spline
Looking like 35 spline and 5/8 will do what I need . Thinking 35 spline is more common .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 04-24-2015, 12:52 PM   #6
71Dragtruck
Re: 35 spline
From what I've heard gun drilled are not recommended on the street, seeing as you have a posi unit I'd assume for some street driving, so just a FYI.
Sponsored by:
Hard Candy Customs
Old 04-24-2015, 12:57 PM   #7
71Dragtruck
Re: 35 spline
I'd say you will be more than fine, I looked at 40 gun drilled with a spool for mine, but decided not as at the time I had dreams of street driving the thing a lot more than I do, but local law enforcement crushed that for me LOL.
But anyway, 35 in a good forged axel will handle lots, I went Moser, Mark Williams were my top choice but too pricey at the time.
Sponsored by:
Hard Candy Customs
Old 04-26-2015, 12:37 AM   #8
moggey01
Re: 35 spline
There not drilled all the way through. It's like 20" from inside edge. Don't know some say it strengthens axles . yeah wanted to drive it some.
Old 04-26-2015, 09:45 AM   #9
Marv D
Registered Truck Offender
Marv D's Avatar
Re: 35 spline
Just a FYI here,, but the maker and hardening process of an axle is JUST, if not MORE important than how many splines,, well to a point that is.
I had a Strange 35spline axle twist with just 580HP (14x32-15 slick dead hooking)
Then I 'exploded' a Dutchman 35 spline axle with the same 580HP
Next I put a nasty twist in a Strange 31spline axle with 660HP
As pair of Moser 31spline axles did better, but has a 1/4 spline twist when I replaced them,,
and I have yet to twist or damage the Mark Williams 31spline axles with 800HP
For whatever thats all worth
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
